Results 1 to 4 of 4
    Established Member Two Rings tquattro2004's Avatar
    May 11 2008
    2004 audi A6 2.7
    new jersey
    Coolant tank Almost bone dry, need help
    2004 Audi A6 2.7T 96,000K
    Hi,
    Tuesday morning I went to start my car, and coolant warning light came on between gauge clusters. Shut car off checked engine bay and coolant tank was bone dry
    I checked coolant and oil 5 days earlier, we got 2 foot snow storm. Coolant tank was full. Drove car Friday it was fine, my girlfriend moved car during snowstorm (without asking ) drove home monday, car was perfect.
    I had timing belt valve covers, coolant flush, new tank put in, thermostat, and housing and alternator done 4 months ago.
    Got coolant filled up 60/40 ratio, waited 5 minutes started car. Exhaust smell was strong, after running for 3 minutes smelled like a rubber burning smell from rear passenger side of engine, and noticed a light smoke. Shut engine off and haven't started car since.
    Anyone ever had this problem?
    Any thoughts where to start looking, or what possibly could be?
    There was no coolant under car Monday or Tuesday, and don't smell burning coolant smell. I'm lost....
    thank yout in advance.
    (Working on adding pic)
    Veteran Member Three Rings carmudgeon's Avatar
    Oct 23 2012
    1995.5 S6 Avant
    Kansas City
    That's the problem with remote diagnosis, I can think of several issues that could have caused it but no way to be sure. E.g, deep snow packed into the front and blocked the radiator, engine overheated and puked its fluid somewhere along the way. Pull the dipstick and make sure its not ingesting it.
    Previous vehicles: 2012 TTS Roadster - 2017 Golf R - 2002 S6 Avant - 2013 S4 - 2008 Subaru STi - 2007 Mazdaspeed3
    Senior Member Three Rings Eurylo's Avatar
    Nov 17 2015
    Earth
    Just had similar issue, there's definitely a leak somewhere- I know the lower radiator hose is prone to failure/ leaking.
    In my case my radiator was cracked by the lower radiator hose that's stupid expensive.
    100 C5's
    Sep 07 2014
    Portsmouth
    S2 had a jammed stat. Did a full drain and fill before the cold snap, or so I thought. After standing a few days bottom rad hose froze solid and cracked stat housing. Sadly I didnt realise till I lost the head gasket.
