Yes, it is very straightforward and well-documented for the B8. B8.5s are possible but more involved/less well documented.
Here's a lengthy thread on it:
http://www.audizine.com/forum/showth...rsion-Complete
You need these three things:
https://www.ecstuning.com/Audi-B8_A4...ghts/ES2500754
http://www.hidconcept.com/d3s-oem-mi...ol-hid-system/
http://www.ebay.com/itm/Xenon-Bi-Xen...259?rmvSB=true
And the coding you'll need to change with a VAGCOM is:
Halogen to bixenon:
09 – Cent. Elect.]
[Coding - 07] -> Long Coding Helper
Byte 0: From 69 → 26 = change from halogen to xenon bulbs
Byte 2: From 00 → 10 = enable LED DRL
Byte 14: From 7F → 1D = bi-xenon high-beams
Byte 15: From 5F → 0D = bi-xenon high-beams
LED brightness:
[09 – Cent. Elect.] [Security Access - 16] (enter security code. One of the default codes is- 20113)
[Adaptation - 10] -> Channel 3
Set between 5 and 100 (set to 30 to avoid error messages)
