Just wanted to double check that I am looking at replacing the right part. I used to run about 23psi, and everything was fine. I recently started having issues with the boost, more pronounced during WOT. It would drop from 23 to 19, raise up to 22, then drop to 15, and then back up to 21/22. I decided to rip out all of the vacuum system a few days ago, and everything was successful there (no CEL). It boosted a little better, but still had the same issue.
Today I replaced all of the remaining vacuum lines with silicone hoses w/ new clamps. Again, it did better, but had the same issue, just less pronounced. I let it sit for an hour before I had to go pick up my fiance for something, and now she won't boost past 7-8psi.
Even back before I had issues like any of this, the turbo just wasn't kicking in like it should. The boost gauge would read about 15psi before I would even start to feel any boost kicking in.
I did a lot of reading up a lot on similar issues, and it all seems to point to the N75. Anyone else pick up the ECS N75 race valve? Or should I just stick to the OEM unit?
Mod list:
Silicone vacuum lines
Silicone TIP
Forge 007 DV piped directly to the intake
Vacuum cluster f&*k delete
K&N drop in filter
APR Stage 2
3" to 2.5" downpipe
Hopefully this can help some others also, as it seems the threads are all scattered with symptoms, and it looks like I have all of them.
