Results 1 to 8 of 8
    Active Member Three Rings auditrackspeed's Avatar
    Jun 17 2014
    Very strange oil leak
    My car does not leak a drip of oil when its just sitting not started . I can start the car almost get the coolant temp up to where it should be without a drip then after that time it starts to drip VERY bad . Did everything i could till this point oil pan gasket. . I really dont want to get raped by a shop . Any help would be really nice.
    Aug 06 2008
    Canadia
    Plugged PCV system?
    the B5 S4 is like the mafia... there is only one way out!
    Jun 17 2014
    Quote Originally Posted by MacDaddy View Post
    Plugged PCV system?
    I dont think so i scraped something then after it started to leak .
    Veteran Member Four Rings Zba's Avatar
    Nov 05 2009
    Denver
    scraped or SCRAPED? Sounds like you have an oil pan issue. Cracked upper or lower pan is my guess.
    It's time to crawl under there and see what's up.
    Jun 17 2014
    Quote Originally Posted by Zba View Post
    already went under lol , i think im gona take off the front clip
    Jun 17 2014
    UPDATE : Went ahead took of the front end . started the car and it leaks from the front crankshaft seal . Is this normal
    Veteran Member Four Rings zillarob's Avatar
    Nov 16 2010
    2kS4, 84gli, 84caddy dsl
    WetSide, WA
    Of course not
    Have you ever replaced it?
    If you want to make sure it isnt the pcv, see if it leaks with the oil cap off (might be a lil messy) or one of the spider connectors pulled of the vc.
    There are only 2 things needed to make an Audi work properly - Duct tape and WD40. If it moves and it shouldn't - Duct tape. If it doesn’t move and it should - WD40.
    Jun 17 2014
    Quote Originally Posted by zillarob View Post
    Of course not
    i have not ever replaced it man , but ill take the oil cap off thanks dude
