well first off new around here. been using the site for all the info i can find. been a big help. thanks
now as for my lighting issues. first time around it was the normal headlight switch contacts. cleaned the thing up worked for about a week. then they went out again this time i installed new switch an found a burnt up wire at the ignition switch. replaced the section of wire an the part of the plug that was melted. turned the light on an only running\parking lights come on. turn on rear fogs an all the lights worked. front an rear fog lights an low beams. that lasted aboout 2 days. now i turn on high beams those work fine as do all other lights except fog front an rear an low beams. so replaced the switch again hopping it was a bad switch. nope still nothing. is there a part of the lighting circuit i am missing? checked fuses, grounds, and traced the wires to the front head light plugs. all good. no brakes pinching or abrasions. the other day i smelt hot plastic smell so i checked the ignition again an no power to the switch for the headlights.
what i need to know is where the power source for the headlights is drawn from. or if there is a control module or something along those lines. ive replaced the ignition switch, headlight switch, length of wire that was burnt, checked grounds/cleaned, traced wires from switch to headlight assembly. an nothing still. im kinda lost with this hole headlight bs that audi decided to not do a recall on. i have to have my lights fixed before i get a ticket for running my high beams all over the place. an only time i drive is before sun up an after sun down. so my lights are essential an i bet people are starting to get pissed bc of the bright lights in their faces every morning.... any and all help would be appreciated thanks
