i got a 2012 Audi a6.... and noticed that it started to leak coolant every so often... basically in about 1 year i had to refill the tank about once....
i also noticed that it only ends up LEAKING when driving above 80 miles an hour.... usually...
Took it to the mechanic and he said he think its the head gasket.... okay.... well we swapped the head gasket... no more coolant leak everything is fine, but i get this engine malfunction...
NO ISSUES with the engine, No issues with timing, starts have no issues, no noises, nothing... just this error.. noticed it comes on after like 10 starts.. WHEN its cold...
any ideas? ANYONE?
attached you will find vag com results! thanks!!!
Tuesday,26,January,2016,21:06:53:11544
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x86
VCDS Version: 15.7.3.0
Data version: 20151216
www.Ross-Tech.com
VIN: WAUGGAFC9DN049527 License Plate:
Mileage: 61630km-38295mi Repair Order:
Chassis Type: FC (4G0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 36 3B 3C 42 44 46 47 52 53
55 56 5F 62 6C 72 8F 90
VIN: WAUGGAFC9DN049527 Mileage: 61630km-38295miles
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
3B-Sensor Elect. -- Status: OK 0000
3C-Lane Change -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
6C-Back-up Cam. -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
8F-Pretens. Frt Left -- Status: OK 0000
90-Pretens. Frt Right -- Status: OK 0000
Address 01: Engine (J623-CTUA) Labels: None
Part No SW: 4G0 907 551 D HW: 4G0 907 551 A
Component: 3.0l V6 TFSIH07 0002
Revision: --H07---
Coding: 0A2A0032052601060000
Shop #: WSC 02391 785 00200
ASAM Dataset: EV_ECM30TFS0214G0907551D 001003
ROD: EV_ECM30TFS0214G0907551D.rod
VCID: 2A5BEA124DD2316E0F-807E
1 Fault Found:
10526 - Camshaft Adj. Bank 2 Intake
P052C 00 [237] - Cold-Start Timing not Reached
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 2
Mileage: 61602 km
Date: 2016.01.26
Time: 07:14:14
Readiness: 0000 0000
Address 02: Auto Trans (J217) Labels: 0BK-927-156.clb
Part No SW: 4G1 927 158 A HW: 0BK 927 156 AM
Component: 0BK 30TFSIUSA H16 1002
Revision: --H16---
Coding: 000002
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_TCMAL551211 002020
ROD: EV_TCMAL551211_AU48.rod
VCID: 2D51E10E7C3C2656EA-8078
No fault code found.
Address 03: ABS Brakes (J104) Labels: 4G0-907-379-V1.clb
Part No SW: 4G0 907 379 H HW: 4G0 907 379 H
Component: ESP PREMIUM H09 0361
Revision: -------- Serial number: --------------
Coding: 44A78F0122E5F1805B00
ASAM Dataset: EV_ESPPremiAU57X 004028
ROD: EV_ESPPremiAU57X_AU57.rod
VCID: 3663CE62896A658E9B-8062
Address 05: Acc/Start Auth. (J393) Labels: 8K0-907-064-05.clb
Part No SW: 4H0 907 064 CR HW: 4H0 907 064 CR
Component: BCM2 2.0 H32 0421
Revision: 00002001
Coding: 0DA82046000000000000
VCID: 7BF51F56FAC878E624-802E
Subsystem 2 - Part No SW: 4H0 905 852 C HW: 4H0 905 852 C
Component: J764 ELV MLB H40 0046
Address 08: Auto HVAC (J255) Labels: None
Part No SW: 4G0 820 043 AH HW: 4G0 820 043 AH
Component: KLIMA 2 ZONEN H11 0076
Serial number: 21081200040020
Coding: 6601201849
ASAM Dataset: EV_AirCondiBasisUDS 002040
ROD: EV_AirCondiBasisUDS.rod
VCID: 65C1592E644CDE16E2-8030
2 Faults Found:
0267 - Sensor for Refrigerant Pressure and Temperature
B10C2 21 [009] - Signal Amplitude Too Low
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 219
Mileage: 61536 km
Date: 2016.01.25
Time: 12:02:07
0315 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 22
Reset counter: 225
Mileage: 61536 km
Date: 2016.01.25
Time: 12:02:12
Address 09: Cent. Elect. (J519) Labels: 4H0-907-063-V1.clb
Part No SW: 4H0 907 063 CG HW: 4H0 907 063
Component: BCM1 2.0 H12 0130
Revision: 11012002 Serial number: 00000001402919
Coding: 0600A011063C9FE08100088380003908CF9CD208A609022100 0004406000
Shop #: WSC 40625 001 104857
VCID: 6FED3B06BEB0144698-803A
Subsystem 1 - Part No SW: 4G1 955 119 HW: 4G8 955 119 Labels: 1KX-955-119.CLB
Component: WWS57X 120720 H36 0080
Coding: 0045F7
Subsystem 2 - Part No SW: 8K0 955 559 HW: 8K0 955 559 Labels: 8K0-955-559.CLB
Component: RLS H04 0003
Coding: 02512B
Subsystem 3 - Part No SW: 4G0 941 531 D HW: 4G0 941 531 D
Component: E1 - LDS H07 0044
Subsystem 4 - Part No SW: 4G0 907 410 A HW: 4H0 907 410 A
Component: USHL4.2 H30 0030
Subsystem 5 - Part No SW: 4G0 907 658 A HW: 4G0 907 658 A
Component: Humidity_Sens H02 0002
1 Fault Found:
01229 - A/C Humidity Sensor (G260)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 3
Fault Frequency: 1
Reset counter: 219
Mileage: 61536 km
Time Indication: 0
Date: 2016.01.25
Time: 12:02:00
Address 10: Park/Steer Assist (J446) Labels: 4H0-919-475-7X2.clb
Part No SW: 4H0 919 475 AG HW: 4H0 919 475 AG
Component: PARKHILFE ACC H01 0072
Revision: 11001001 Serial number: 61061222203721
Coding: A8C305
ASAM Dataset: EV_EPHVA18AU57X0000 003008
ROD: EV_EPHVA18AU57X0000.rod
VCID: 77FD0366CEE05C8640-8022
Address 15: Airbags (J234) Labels: 4H0-959-655.clb
Part No SW: 4G0 959 655 A HW: 4G0 959 655 A
Component: Airbag10.43 H32 0032
Revision: -------- Serial number: 003D8002BH1C
Coding: 303234373131303030314A55304C34473053
ASAM Dataset: EV_AirbaAU10BPAAU64X 001014
ROD: EV_AirbaAU10BPAAU64X_AU57.rod
VCID: 3365F7769A1870A6BC-8066
Seat occupied recognition:
Subsystem 1 - Part No SW: 5C6 959 339 A HW: 5C6 959 339 A
Component: BF-Gewichtss. H10 0045
Serial number: 6940000Y120000HL5K0X
Crash sensor for side airbag; driver side:
Serial number: 3575HRB40571G1DMCOT.
Crash sensor for side airbag; front passenger side:
Serial number: 3585HRB40591G1DM61H%
Crash sensor for side airbag; rear; driver side:
Serial number: 3515JRB405V1DKAS5O63
Crash sensor for side airbag; rear; passenger side:
Serial number: 3525JRB405N1AP604GJD
Crash sensor for front airbag; driver side:
Serial number: 3554VRB400E4UIV889DA
Crash sensor for front airbag; front passenger side:
Serial number: 3564VRB400I4UIV8P1LW
Address 16: Steering wheel (J527) Labels: 4H0-953-568.clb
Part No SW: 4G0 953 568 A HW: 4G0 953 568 A
Component: Lenks.Modul H05 0201
Revision: 00000000 Serial number: 20120814000421
Coding: 000034
VCID: 306FF87A630E4BBEC1-8064
Subsystem 1 - Part No SW: 4G0 951 528 A HW: 4G0 951 528 A
Component: E221 - MFL H08 0010
Address 17: Instruments (J285) Labels: 4H0-920-xxx-17.clb
Part No SW: 4G8 920 983 E HW: 4G8 920 983 E
Component: TBenUsa H79 0515
Revision: 28460207 Serial number: 658310712596040
Coding: 03E709040B41D705020000
ASAM Dataset: EV_RBD4K 004046
ROD: EV_RBD4K.rod
VCID: 377DC3668E609C8680-8062
Address 19: CAN Gateway (J533) Labels: None
Part No SW: 4G0 907 468 AC HW: 4G0 907 468 AA
Component: J533--Gateway H11 0035
Revision: -------- Serial number: 00000000646250
Coding: 00CD073000
ASAM Dataset: EV_GatewPkoUDS 001016
ROD: EV_GatewPkoUDS.rod
VCID: 71E93D7EA08402B68E-8024
Battery Monitoring Control Module:
Subsystem 1 - Part No SW: 8X0 915 181 HW: 8X0 915 181
Component: J367-BDM H07 0141
Serial number: 00000000003790101309
Voltage stabilizer:
Address 36: Seat Mem. Drvr (J136) Labels: None
Part No SW: 4G8 959 760 HW: 4G8 959 760
Component: MEM-FS H03 0154
Revision: AA000000 Serial number: 00000036144309
Coding: 00581B0000006001000001010101102030303232203232
VCID: 77FD0366C6E05C8640-8022
Address 3B: Sensor Elect. (J849) Labels: 4G0-907-637.clb
Part No SW: 4G0 907 637 K HW: 4G0 907 637 F
Component: SARA 6D H02 0053
Revision: -------- Serial number: EJ1BPA8200YDV$
ASAM Dataset: EV_SARA2 005011
ROD: EV_SARA2_AU57.rod
Address 3C: Lane Change Labels: Redir Fail!
Part No SW: 4G0 907 566 D HW: 4G0 907 566
Component: J769 SWA MasterH01 0040
Revision: 00H01000 Serial number: 6PZ 010 287-03
Coding: 0000001
VCID: 306FF87AA30E4BBEC1-8064
Subsystem 1 - Part No: 4G0 907 568 D
Component: J770 SWA Slave H01 0040
Subsystem 2 - Serial number: 6PZ 010 287-23
Subsystem 3 - Serial number: 5F16.08.1200H010003CF20145ÿ
Subsystem 4 - Serial number: F20145ÿ
Address 42: Door Elect, Driver (J386) Labels: None
Part No SW: 4G8 959 793 J HW: 4G8 959 793 G
Component: TSG FA H03 0506
Coding: 011F17005E00628002000012
VCID: 479DB3A6F680EC06F0-8012
Address 44: Steering Assist (J500) Labels: 8K0-909-144.clb
Part No SW: 4G0 909 144 L HW: 4G0 909 144 G
Component: RCEPS H36 0010
Revision: 00001000 Serial number: 0030760768
Coding: 101000010000
ASAM Dataset: EV_RCEPS 009008
ROD: EV_RCEPS.rod
VCID: 326BF272650279AEB7-8066
Address 46: Central Conv. (J393) Labels: 4H0-907-064-46.clb
Revision: 00002001 Serial number: 0182035052
Coding: 0106023A003A408580B008040205030F000000000000000000 0000000000
Shop #: WSC 06342 000 00000
Subsystem 1 - Part No SW: 4G0 959 719 HW: 4G0 959 719
Component: GTO BF H01 0080
Subsystem 2 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H05 1501
Subsystem 3 - Part No SW: 4G8 959 591 HW: 7P0 959 591 C
Component: J245 PS40.039 H01 0008
Coding: 101F00
Address 47: Sound System (J525) Labels: None
Part No SW: 4G0 035 223 C HW: 4G0 035 223 A
Component: BOSE-G3-C7 H07 0160
Revision: CJ007001 Serial number: 00000000078920
Coding: 010000
VCID: 1D3131CE049CD6D67A-8048
Address 52: Door Elect, Pass. (J387) Labels: None
Part No SW: 4G8 959 792 J HW: 4G8 959 792 G
Component: TSG BF H03 0506
Coding: 011F17005E00628002000002
VCID: 4683BEA2F18AF50E0B-8012
Address 53: Parking Brake (----) Labels: 4H0-907-801.clb
Part No SW: 4H0 907 801 F HW: 4H0 907 801 A
Component: EPB-4 H03 0013
Revision: -------- Serial number: 00000000433162
ASAM Dataset: EV_ParkiBrake 001027
ROD: EV_ParkiBrake_AU48.rod
VCID: 2B55EF1642282866F4-807E
Address 55: Headlight Range (J431) Labels: 8X0-907-357.clb
Part No SW: 4H0 907 357 B HW: 4H0 907 357 B
Component: ....LWR12.... H02 0010
Serial number: 120820-0002-108
Coding: 1221A6101002A500
ASAM Dataset: EV_HeadlRegulBasic 005001
ROD: EV_HeadlRegulBasic.rod
Address 56: Radio (R) Labels: Redir Fail!
Part No SW: 4G0 035 082 D HW: 4G0 035 082
Component: Radio U SIRIU H60 0112
Revision: AB001007 Serial number: 156HZ0C7625142
Coding: 020007010000000001
VCID: 21490D3E38E4F2365E-8074
Address 5F: Information Electr. (J794) Labels: 4E0-035-6xx-5F.clb
Part No SW: 4G0 035 746 B HW: 4G0 035 746 B
Component: H-BNT-NA H49 0549
Revision: -------- Serial number: 194H/0C7510449
Coding: 050200000003E0EF55128B3E00000003100001000000000000
Shop #: WSC 40625 001 1048576
VCID: 26431E2251CA150E2B-8072
Subsystem 1 - Part No: 8R0 060 884 AM
Component: NAR 2012 0605
Subsystem 2 - Part No SW: 4G0 919 605 B HW: 4G0 919 605 B
Component: DU8 C7 SV H42 0021
Subsystem 3 - Part No SW: 4G1 919 610 C HW: 4G1 919 610 C
Component: E380 BDT C7 H11 0204
Subsystem 4 - Part No: 8R0 060 961 D
Component: CD-Database 4353
Address 62: Door, Rear Left (J388) Labels: None
Part No SW: 4G8 959 795 J HW: 4G8 959 795 G
Component: TSG HL H03 0506
Coding: 010F17004000628002000002
VCID: 4999B59EE0941A76E6-801C
Address 6C: Back-up Cam. Labels: 4H0-907-441.clb
Part No SW: 4G0 907 441 B HW: 4H0 907 441
Component: SG Rueckfahrkamera 0061
Revision: --H06--- Serial number: 525 PA8J27G5T1
Coding: 1080004
VCID: 26431E2291CA150E2B-8072
Address 72: Door, Rear Right (J389) Labels: None
Component: TSG HR H03 0506
Address 8F: Pretens. Frt Left (J854) Labels: 4H0-980-94x-RGS.clb
Part No SW: 4H0 980 945 B HW: 4H0 980 945 C
Component: RGS-VL H13 0080
Coding: 0006E008031F0300070308014244CA010000
ASAM Dataset: EV_RGS_L 002004
ROD: EV_RGS_L.rod
VCID: 3169FD7E600442B6CE-8064
Address 90: Pretens. Frt Right (J855) Labels: 4H0-980-94x-RGS.clb
Part No SW: 4H0 980 946 B HW: 4H0 980 946 C
Component: RGS-VR H13 0080
ASAM Dataset: EV_RGS_R 002004
ROD: EV_RGS_R.rod
End-------------------------(Elapsed Time: 05:46)--------------------------
