Results 1 to 13 of 13
    Established Member Two Rings B8Nate's Avatar
    Dec 21 2015
    2012 MK6 Jetta S
    Little Rock, AR
    PCV Delete .. Any Drawbacks?
    Just as the title states, when I bought my Audi I had a bunch of carbon build up (misfires, rough idle) and so I cleaned it out about 3k miles ago. When I did the carbon cleaning, I had a local guy tell me he had a PCV delete installed (that vents to the atmosphere) and he said he's never had any issues with carbon deposits on any of his Audi's (has 3 of them) so I did a little research and even searched on here and have seen a few members on here who have added a catch can + pcv delete setup and have had good things to say about no more carbon build up and stuff, but none who have really JUST installed the pcv delete and vented it to the atmosphere, is there any drawbacks to venting it to the atmosphere? I've heard it has a smell when vented to the atmosphere I'm not so worried about that, seems like it should solve my future carbon problems and for $89.99 I'm def okay with that being the only drawback. So with all that being said, can anyone agree with just a pcv delete helping carbon buildup? Or have any reason why I'd HAVE to have a catch can as well or any drawbacks to just having the pcv delete?
    Thanks!!
    B8 A4 Quattro | Meteor Pearl Grey | K04 Turbo | Carbonio APR Intake | APR Catback | APR Turbo Muffler Delete | Forge DV | APR Downpipe | KW V1 Coilovers | Rotiform SPF 19x10 +35 | S4 Tie Rods | Rieger RS5 styled Front Bumper Conversion | Rieger Rear Diffuser | Rieger Side Skirts | Carbon Fiber Duckbill Spoiler
    Sep 24 2014
    2015 Audi Q3 Quattro, 2017 Corvette M7 Grand Sport, 2017 Audi SQ5, 2019 Porsche Macan, 24 Jetta GLI
    Central NJ
    You will still get some carbon build-up on the back of the intake valves, as some oil normally seeps down the valveguides and gets baked onto the back of the valve from the valve-overlap technique used for EGR.
    Veteran Member Four Rings adamazing's Avatar
    Apr 26 2014
    San Diego, CA
    You need a vacuum source to extract the gasses. Where does the Delete Ket get vacuum from?
    2013 A4 Quattro Green Black Iridescent / APR E85 Stage 2 / AG F421 Polished Copper / Eurocode FMIC + HFC / AWE Quad + CF Diffuser
    build / instagram / flickr
    Sep 09 2010
    Destin, FL
    Just get a catch can or build your own. A delete wouldn't workout.
    Dec 21 2015
    2012 MK6 Jetta S
    Little Rock, AR
    Quote Originally Posted by S4'ed View Post
    Okay thanks. That's all I was wondering. So catch can + pcv delete it is.
    Quote Originally Posted by adamazing View Post
    I'm not 100% sure, that's why I asked on here. It does have a hole that mounts the vent tube to it. And then the delete kit that's made for a catch can actually filters it back to the intake so it creates a vacuum for sure.
    Quote Originally Posted by The Infiltrator View Post
    Okay thank you very much for all your answers. Got it now! Thanks guys!
    Jun 02 2014
    Lake Tahoe
    I've had the intake manifold side of my PCV venting to atmosphere for about 30k miles with no side effects (120k mi. on the car). There's still vacuum whenever you're under boost. I do plan on blocking off the turbo side to prevent oil from dripping into compressor housing, and running both the PCV intake manifold & turbo side outlets into the exhaust w/ a slash cut Moroso nipple. IE makes block off plates & adapters to do exactly this, and it provides plenty of vacuum on the crankcase using the stock PCV system. The setup i have now cost ~$12 and is reversible in 2 minutes. Full "delete" is probably $100.
    Dec 21 2015
    2012 MK6 Jetta S
    Little Rock, AR
    Quote Originally Posted by Stoff View Post
    So as of right now, you only having it venting to the atmosphere and no issues?
    Jun 02 2014
    Lake Tahoe
    Correct. Just pull the plastic line from your PCV to the intake manifold. Then buy a tiny $9 cone filter from autozone and jam it in the PCV (I think I cut the rubber on the filter a bit so it would fit), and a freeze plug to stick in the hole on the intake manifold. I can't remember the sizes but it's very self explanatory once you look at it. Just make sure the freeze plug is in nice & tight since it'll be pressurized.
    Dec 21 2015
    2012 MK6 Jetta S
    Little Rock, AR
    so essentially you're just removing the plastic line/hose from the PCV to manifold. Plugging the open end on the manifold with a freeze plug and replacing the opening on the pcv side with a small cone filter from auto store for ventilation?
    Dec 21 2015
    2012 MK6 Jetta S
    Little Rock, AR
    Sounds like a plan I guess it won't hurt to try it, think I'd rather use a rubber vacuum boot to cap off the end and maybe a very small hose clamp since that would hold the pressure a little better I feel and wouldn't ever risk "popping" out. But yeah, still sounds like a good setup.
    Jun 02 2014
    Lake Tahoe
    The freeze plug seemed sketchy at first but I'm running a K04 and it's never budged. There's always this little guy if you're worried about it / ever want a boost tap. IE BOOST CAP FOR FSI, TSI, AND 2.5L 5CYL ENGINES
    Dec 21 2015
    2012 MK6 Jetta S
    Little Rock, AR
    yeah man I'm also k04 , but yeah I would think a cap with a small hose clamp paired with the small filter allowing the pcv to vent, would solve my issue. Thanks in advance man! I'm going to run it as a little DIY project when I get around to it like with the rest of my car, if I like it, I'll keep it around, if not I guess I'll run a catch can + full delete.
    May 15 2019
    2007 Mercedes C230 Sport, 2006 Chrsler Serbring, 2006 Volvo S60 2.5T, 2006 A4 Quattro 2.0T
    Bellevue, WA
    no regrets yet. Entire DD42 catch can+ block off plate + fog lights cost me 110 with shipping. If I feel like maintaining catch can is too much, i will shift back to PCV again.
