Results 1 to 40 of 50
    Veteran Member Three Rings HUFset's Avatar
    May 08 2014
    B5 A4 GTRS, MK4 Jetta F21T
    CLFX, Denver
    OEM+ Audi B5 B6 MK4: RS4 TB, TT Carriers, S4 Headliner Swap, Forge 007 etc
    Check out my CL ad in Denver for contact info and pictures. I will ship almost anything at your cost. Prices in CL ad are for local pickup.
    http://denver.craigslist.org/pts/5886629795.html
    I UPDATE the parts list in this ad with new parts FREQUENTLY. Please read the entire ad as it is constantly changing.
    If the parts are listed I still have them.
    I am willing to ship and bundle parts for payment VIA PayPal at the buyers expense. All sales are as is and FINAL unless I agree to some other term after the transaction.
    1x B5 RS4 75mm Throttle Body (07D 133 062). This works with the RS4 intake mani or the S4 intake mani with a throttle body adapter plate. Some Throttle Body Boots will be able to fit on with massaging. $150
    1x Audi TT front caliper carriers for 312mm vented rotors on B5 A4 Passat This is the cheapest, easiest bolt on OEM+ front brake upgrade for your B5. Uses stock knuckle location to mount your stock calipers and upgrades your front brakes to allow bigger rotor and venting. $120
    1x B5 S4 Headliner Set in Onyx/Black NOT a complete set. The set is missing a sunroof slider. This is a sweet full black interior upgrade for B5 A4s $200
    1x B5 S4 Headliner in Onyx. Has sag in rear for $40. Sag can easily be fixed w/steamer and paint roller or some new adhesive before install.
    1x B5 S4 A pillars in Onyx. Some minor defects. No broken tabs. Have airbag plugs. $40
    1x B5 A4 S4 MK4 1.8T 2.7T Forge 007 Diverter Valve Polished billet aluminum DV in excellent condition. All o-rings are in good shape, it has been cleaned and re-lubed/serviced. Superior aftermarket, quick response DV that is re-buildable and serviceable. No longer made, like new $140
    1x B5 S4/RS4 AllRoad A6 2.7t RS4 85mm Intake Accordion Hose (078 129 627 P) $50
    2x B5 S4/RS4 AllRoad A6 2.7t Beru ICMs $20ea
    1x B5 S4/RS4 2.7T K&N style drop-in airfilter for airbox Could fit other airboxes $10
    1x B5 A4/S4 Independent Fog Light Relay. Modified to run your fog lights without turning on your headlights (see picture). This is an easy plug and play 5min install. (8D0 907 01 B) $30
    1x B5 A4/S4 Battery Tray Cowling(8D1 819 447 A) with rubber $40 and Battery Cover (8D1 819 422) $15 $50 total
    1x B5 A4/S4 Aero Wiper Arm Conversion Set. Improved wiping at higher speeds where wiper will not hop/skip, sleek low profile where arms are unnoticeable at rest from driver seat(See Picture), sits below wiper blade instead of on top. Effectively scooping and wiping debris instead of running over it. OEM plus look. Used $40/pair
    1x A3/A4/A5/A6/S4/RS4/Q5/Q7 Multifunction Steering Wheel (MFSW) Controls (mode/BT/Vol/scan) (4F0 951 527 C) $40
    1x OEM Audi mobile phone Pure nostalgia. Plug it in to complete your accessory package. Marvel at its epic greatness. Convert it to a bluetooth headpiece. $20
    2x B6 A4/S4 Rear Rubber Floor Mats in black (8E0 061 511 041) $30
    1x B5 A4/S4 set of PreFacelift Taillights inblack. Excellent condition easy to modify(swap wires 2and4 in connector) to light up on your Facelift A4/S4. Stand out and look different! $50/pair
    1x B5 A4/S4 Front Seat Track End Covers, unbroken w/ no screw covers in Terra Cotta $10
    1x B5 A4/S4 Passat Roof Mounted Sunglasses Holder in Grey. Fits in roof handle location. They hold large sunglasses easily. OEM $10
    1x C5 Allroad Bumper Mesh Grille OEM. All three pieces including fog light holders. $50/set
    1x MK4 Jetta/Golf/GLI/GTI/R32/Beetle Donut Headrests in black cloth for front bucket seats. $30
    1x B6 A4 Cabin Filter Cowling OEM (8E1 819 447 A) $15
    1x B5 A4/S4 OEM Wiper Arm Set, hook style. $10
    3x B5 A4/S4 Complete OEM First Aid Kit(8D0 860 281 C) $10
    1x B6 A4/S4 A6 A8 Black Trunk Net (8E5 861 869) w/ pouch area $40
    1x A4/S4 A6 A8 Beige Trunk Net (4A9 861 869) $15
    1x A4/S4 A6 A8 Black Trunk Net (4A9 861 869) $25
    1x '97 B5 A4/Passat Computer/ECM/ECU for 1.8T with AEB engine code, drive by cable(8D0 907 557 N) Already have a tune and want a new one? Use this ECU and sell your old one instead of writing over it to regain money! $40
    1x '01-02 B5 A4/Passat Computer/ECM/ECU for 1.8T drive by wire(4B0 906 018 CH) Already have a tune and want a new one? Use this ECU and sell your old one instead of writing over it to regain money! $40
    1x C5 A6 Oversized PS Reservoir Cover $5
    1x B5 A4/S4/Passat C5 A6/S6/Allroad Boxster Sachs Throw-Out Bearing(04 3151 2719 37) $25
    1x B5 A4 Grey Headliner Pieces(lights, handles) $20
    1x B5 A4 Grey Headliner great condition, no sagging $25
    4x B5 B6 A4 Cigarette Lighter $5ea
    4x 710/A/B Diverter/Bypass Valve (fits audi, porsche, saab and VW 1996-2002 turbo cars) $5
    1x B5 A4/S4 Rear Differential Carrier (8A0 599 133 B). Bushing still in good shape. $20
    1x B5 A4/S4/Passat Slotted Coolant Cap from A3, different than most, blue $10
    1x B5 A4/Passat N112 Valve $20
    1x B5 A4/Passat N249 Valve $20
    I am WILLING TO TRADE my parts and cash for: Rear Black A4 Bumper, Black B5 facelift driver fender, 5x112 WCI or Rotiform wheels, LC-1, UEMO or Zeitronix wideband, B5 or B6 vent pod for gauges, Cupra R lip, B5 RS4 door handles(black), RS4 grille, B5 In.Pro mirror housings, Depo E-Codes w/ city lights, CX Racing intercooler piping, Treadstone FMIC, 034 B5 A4 1.8T FMIC, AEM water meth nozzle, 034 sub frame bushings, water-meth bungs, silicone engine hoses (black), B5 cold side intercooler piping, manual boost controller MBC, Silver B6 door blades, B6 S4 lower center grille, Apikol B5 bushings for rear diff carrier, B5 DTS Drive Train Stabilizer, B5 034 or Hotchkiss Rear sway bar and reinforcements, GT28RS, Maestro Tuning Suite, AEM Methanol Injection Nozzles, wheel spacers and a wheel stud conversion kit
    Keywords: Audi VW Volkswagen AE 18T turbo EVO AEM draft design APR GIAC 5x112 Motoza B5.5 B7 B8 B8.5 RS4 Snow Performance Devils Own methanol innovate 034 IE Integarated engineering Forge bypass garrett precision borg warner cold air intake chip chipped C2 PES magnaflow billy boat borla xs-power ftg SRM project B5 ECS modded mods tubobits go fast HFS4
    2000 A4 1.8TQM|GTRS Elim|550cc Maestro|034 AEM WMI|ECS RA4|Carbonio CAI|034/Borla TBE|CTS FMIC|2.0T/AWP harness|Toy Guy/JHM duo SS|034 mounts|034 CAs/Links|ST Coilovers|A6 Strut Brace|ECS RDiff Mount|Apikol Rear Diff Bushings|A4 Sport Cloths|Euro S3 FBMFSW|B6 S4 Rearview|Euro Bolster|All S4 Interior/Exterior Bits|Sport Mirrors/Trim|M3 Spoiler|Aero Arm Wipers|OEM Votex Rack and A4 Bra|A8 Fat Fives|S4 Cluster|P3 VIDI Gauge|Pioneer AVH-X4700BS|Alpine PDX-V9|6 Polk DB Mids|Eclipse 12"
    Senior Member Two Rings MarcRogers's Avatar
    Jan 18 2016
    PA
    Ughhhh I swear if I didnt live in philly that trunk would be mine. What about those breaks tho are they for an S4 or A4?
    May 08 2014
    CLFX, Denver
    Quote Originally Posted by MarcRogers View Post
    PM'd
    Junior Member One Ring
    Jan 07 2016
    Conway ar
    What would just the black six pillars set me back?
    May 08 2014
    CLFX, Denver
    Quote Originally Posted by ketcherB5 View Post
    Some guy is going to come pick up the entire headliner set today, locally. If that falls through I'll quote you a shipped price.
    Jan 07 2016
    Conway ar
    Did he get the set?
    May 08 2014
    CLFX, Denver
    Did he get the set?
    Pushed it back to Saturday. He buys a lot of parts from me. I doubt it falls through.
    May 08 2014
    CLFX, Denver
    Bump
    May 08 2014
    CLFX, Denver
    Bump for new parts
    May 08 2014
    CLFX, Denver
    TTT
    May 08 2014
    CLFX, Denver
    Bump for new parts.
    May 08 2014
    CLFX, Denver
    Parts list updated
    May 08 2014
    CLFX, Denver
    bump
    Established Member Two Rings Audixx4's Avatar
    Sep 10 2010
    Tucker,GA
    Still have the cup holder?
    May 08 2014
    CLFX, Denver
    Quote Originally Posted by Audixx4 View Post
    No, sold. I have a Credit Card Holder left.
    Senior Member Two Rings Spectre1130's Avatar
    Jan 08 2012
    2015 VW GTI
    Colorado Springs, CO
    Curious on the ECU's. What's the difference between the 8D0 907 557 N and the 8D0 907 557 P? I will need to look at mine to see which it is, but I may buy one.
    97 A4 1.8t: Reflect 650cc, T3 6063 turbo, turbo back exhaust & FMIC, top mount manifold, Apex lowering springs, 81.5mm bore, Supertech pistons, Eagle H beams
    May 08 2014
    CLFX, Denver
    B5 A4 S4 Parts(Euro Trunk,S4 Valence,Headliner,Aero Arms,Mirror,Nets)
    Bump
    May 08 2014
    CLFX, Denver
    Quote Originally Posted by Spectre1130 View Post
    I think one is auto(N) and one is manual(P) trans. I really have no idea both came off cars with AEB engines. Rule of thumb is to match what you currently have.
    Established Member Two Rings On3ok?'s Avatar
    May 10 2015
    Milford Delaware
    Carbon fiber Exterior pillars + shipping is 60?
    Sent from my SM-N915P using Tapatalk
    May 08 2014
    CLFX, Denver
    Quote Originally Posted by On3ok? View Post
    Carbon fiber wrapped exterior b pillars are $60 plus shipping. Im looking for $70 shipped.
    May 10 2015
    Milford Delaware
    Quote Originally Posted by HUFset View Post
    Can i get a picture of it?
    May 08 2014
    CLFX, Denver
    Wrapped in the VVivid 3D Carbon fiber that is less glossy and better for exterior applications and looks/lasts better in direct sunlight.
    May 08 2014
    CLFX, Denver
    Sold and shipped several parts yday. List updated.
    May 08 2014
    CLFX, Denver
    Pictures updated bump!
    Nov 19 2008
    San Antonio
    I just picked up a brilliant yellow 2001 1.8t manual that has HID lights and a three spoke steering wheel without any controls. I got the bug and I want to get to modding this thing right away. What do you have in this long list of parts that you think I need to make my ride better?
    May 08 2014
    CLFX, Denver
    May 08 2014
    CLFX, Denver
    Quote Originally Posted by Imakulate View Post
    I don't have any performance mods right now, just cosmetic. Aero arms, independent fog relay, carbon exterior b pillars, rear S4 door cards, sunglasses holder, first aid kit. With brilliant yellow paint you could buy the euro trunk and rear lower s4 valence.
    May 08 2014
    CLFX, Denver
    bump
    May 08 2014
    CLFX, Denver
    bump
    May 08 2014
    CLFX, Denver
    parts list updated and price changes made.
    May 08 2014
    CLFX, Denver
    parts list updated with new additions and recent sales. New Santorin Euro trunk in excellent complete condition! You can mount it today. Pictures to come soon. I will be washing, polishing and waxing it today.
    May 08 2014
    CLFX, Denver
    bump
    Veteran Member Four Rings reece_2212's Avatar
    Apr 22 2016
    Alberta, Canada
    HID ballasts still available?
    '96 A4 2.8QM - (RIP Avocado) <3
    '01 A4 1.8tQM - GT2860RS Elim, 550cc, APR Carbonio, Clutchmax Stage 2 w/ SMFW, APR FMIC, IE Rods - Bilstein B8, Tein S Tech, 034 Trans Mounts, ECS Poly Snub, Stern Engine Mounts - B7 A4 Front Brakes, C5 S6 Rear Brakes, Stoptech Stainless Lines - eBay SS, 3D Printed Shifter Cage, JHM Linkage Bushings -
    May 08 2014
    CLFX, Denver
    Quote Originally Posted by reece_2212 View Post
    Yes they are. My contact info is in the CL ad. PM Sent.
    May 08 2014
    CLFX, Denver
    bump
    May 08 2014
    CLFX, Denver
    bump
    May 08 2014
    CLFX, Denver
    Bump for H&R coilovers, S4 Headliner bits and other little things.
    Established Member Two Rings cwatson427's Avatar
    Aug 21 2016
    rhode island
    Still have the trunk? Also do you happen to have a fmic you would be looking to get rid of?
    May 08 2014
    CLFX, Denver
    Bump
    May 08 2014
    CLFX, Denver
    Quote Originally Posted by cwatson427 View Post
    I still have the trunk. Can ship via Greyhound. Text me for more pics(contact info in CL ad). Paypal is [email protected].
