Thread: Dark MMI
    May 12 2014
    Montreal, Qc, Canada
    Angry Dark MMI
    Hello, recently my MMI has been going bright/dark for no reason. I'm not sure whether it's the light sensor issue, but it's really dark most of the time. I also considered it's the backlight that's busted, but I'm not sure.
    The MMI is now mostly all the time very dark, I can barely see what's written on it. It happens that sometimes I start the car, and the MMI is bright, but then fades soon enough.
    I searched the forum, and found a couple of posts, but no solutions.
    Established Member Two Rings mahunik's Avatar
    Dec 06 2015
    New York, Clifton Park
    My MMI was very dim on my Audi during the day so I just went into the settings and adjusted it to be a higher brightness. Or if you already did that then possibly the screen is havent some problems.
    Jul 16 2008
    Finland
    You can swap out the back light. You need:
    CCFL tube: 2.2 x 148mm Full Spectrum CC22148
    End caps: SILICONE END jpojp 1 1.50 Size = 2.2mm
    and a little bit of soldering experience.
    ______________________________________
    2013 A4 B8.5 Avant 1.8tfsi quattro, Ibis White. Mods: 8x18 OZ Leggera HLT for winter, OEM RS4 9x19 for summer, OEM trunk organizer rails, Underseat storage bins, S4 pedals, LED interior lights, H&R Sport, tint.
    May 12 2014
    Quote Originally Posted by TDIaholic View Post
    Do you know exactly where to purchase these? Are they common ?
    Jul 16 2008
    Finland
    You should be able to find them at any well stocked electronics store that sells DIY computer hardware, or even ebay.
