    Senior Member Two Rings nemick's Avatar
    Aug 22 2012
    Indianapolis, IN
    About how long should it take me to remove the rear subframe?
    I'm replacing the subframe bushings and trying to figure out a schedule.
    Neil M.
    2004 allroad 2.7T TIP
    2001 A4 1.8TQ, TIP
    Veteran Member Four Rings melomandn's Avatar
    Nov 08 2010
    958 CTT, 996 C4S, old motorcycles
    Upstate New York
    Does your area use salt on the roads? If so you're looking at a full weekend of frustratioin
    - B7 avant, 3.0t swapped
    - B8 S4, Stage 2+
    - B6 S4, not stock
    - B5 S4 Clone, built motor, 2871r
    Dec 10 2013
    Borden, Ontario, Canada
    Took 2 full days with hand tools on my S4. Lining up the subframe to get it straight is going to be the biggest hurdle, besides rusty bolts and nuts
    Everything graciously mispelled by Android
    IG: 24_et
    Sold:
    2010 Deep Sea Blue S4 6-spd
    RIP:
    Dec 10 2013
    You'll also have to burn out the old ones
    IG: 24_et
    Sold:
    RIP:
    Aug 22 2012
    Indianapolis, IN
    Sure sounds like it will be a major project. I guess I better really confirm I need new bushings before just jumping in then. Thanks all
    Neil M.
    2001 A4 1.8TQ, TIP
