Results 1 to 40 of 61
    Senior Member Three Rings CapnToll's Avatar
    Apr 18 2014
    '17 C63S AMG Coupe, '96 Acura Integra
    Alberta, Canada
    2014 S5 - Center Diff Leak - Dealer TD1 Warranty Form Submitted - APR Stage 2+
    So apparently I've got a center diff leak - car is in for my 25,000 km service.
    They're doing what they can to have it covered under warranty - submitted the TD1 warranty claim form. I'm sure hoping Audi decides to be nice and cover it. Otherwise hope it's not the most expensive fix in the book...
    Anybody else ever get a center diff leak (don't have any more info at this point), either tuned or untuned?
    2014 Audi S5 FOR SALE: http://www.audizine.com/forum/showth...ll-the-goodies
    DSG - Phantom Black - Black Nappa Leather w/ Chestnut Brown Inserts - Beaufort Wood Inlays - Sports Diff - Adaptive Dampers - APR Stage 2+ Pulley/93 Tune - CTS Intake w/ Heat Wrap - 323whp @ 3000' (AWE intake)
    Jul 16 2012
    Mid-Atlantic
    Quote Originally Posted by CapnToll View Post
    Not to sound insensitive to your issue, but why in the heck would you bring your car in for a one of the scheduled services and not have it flashed to stock beforehand at a minimum?
    Veteran Member Four Rings superswiss's Avatar
    Jan 07 2013
    San Francisco Bay Area, CA
    Not trying to scare you, but the center diff is fully integrated into and part of the whole transmission. It's the red part on the far right. So, they probably have to take out the entire transmission and open it up. Just guessing here, but I don't think this is gonna be cheap if Audi doesn't cover it.
    2019 AMG C63CS, obsidian blk, blk leather w/ yellow stitching, aero pkg, CF pkg I+II, 19/20 wheels, lighting pkg, multimedia pkg, heat&vent seats, AMG perf seats, digital cluster, night pkg, parking assist, driver assist, european delivery
    2013 panther blk RS5, Ti pkg, blk leather/alcantara, nav pkg, sport exhaust, driver assist pkg, rear shade, alu kreuz, ECS spacers 15f/10r, ECS tru-float rotors, ECS brake lines, Hawk HPS pads, european delivery (sold)
    Apr 18 2014
    Alberta, Canada
    Quote Originally Posted by Works2shoot View Post
    I had the entire tune uninstalled before my first service (was switching from GIAC to APR) and they still flagged the car when there was no tune on it. I assume the ECU memory shows that the software was opened up.
    Jul 16 2012
    Mid-Atlantic
    That's Crazy!! Are you sure that the "uninstaller" just didn't put it in stock mode since it was being reflashed anyway?
    Mar 21 2015
    Waiting for the answer to that^
    Apr 18 2014
    Alberta, Canada
    No I went to the shop that put GIAC Stage 1 on it, had it completely removed and received my full refund. Went for my first service when it was flagged and then went to a different shop to have APR Stage 2+ installed with the pulley.
    Mar 21 2015
    ^ That sucks real bad! I hope it's not as bad as you think.
    Jul 16 2012
    Mid-Atlantic
    Was there an issue with the tune that caused you to go for a refund? Could have been a disgruntled shop owner. The reason we are so curious is because we thought that erasing the tune prevented TD1.
    Nov 28 2015
    Montreal, QC
    oush... that suck badly.... :S goes to show that even with stage having the option to revert to stock it can still be flagged anyways.. was about to pull the trigger on a stage 1.. guess i will wait 20 months before doing so :( Hopefully for you it's OK, but being a tranny part, I'm sure they can blame the additional torque of the tune to have damaged the tranny component.
    Veteran Member Four Rings Race Shooter's Avatar
    Dec 22 2006
    Raleigh
    I think it depends on the tune. APR says when they go back to stock, they adjust the flash counter to go back to its previous number. I'm not sure that GIAC or the others have that capability.
    If they flash it back to stock, that will show an additional flash on the ECU. So if you go in for service and it shows 0 flashes. Then you get a tune, the ECU now will show 1. If you get it flashed back to stock, the ECU now shows 2. Audi would know its been flashed twice since the service that showed 0.
    So the tune you have, needs to have the capability to adjust the ECU's counter.
    Simply flashing back to stock is not a sure way to avoid TD1.
    2014 Porsche Cayman S Guards Red
    2015 Sepang Blue S4 6MT Gone...easily forgotten.
    2004 Nogaro Blue S4 Avant 6MT Gone...but severly missed .
    Jim Sykes Photography motorsports photography
    Veteran Member Four Rings jran76's Avatar
    Jun 20 2011
    2002 Audi S4
    Plano, TX
    I think it comes down to if you tune your car, you need to be prepared that Audi may be able to detect it. It's a constantly evolving process, and what's true today may not be tomorrow. This applies to any tune, flashed or piggyback. Even outside of the TD1 auto-scan, if Audi/AOA really wants to figure out if you have been tuned, they likely can. With any type of tuning, there are parameters that are changed well outside their normal operating range, and there is enough of a digital trail to find those if they are willing to look hard enough.
    2018 S4 : Daytona Gray : Black Nappa : Carbon Atlas : S Sport : Black Optics : 034 Springs/Rear Sway Bar/Inserts : 19x9.5" BBS CH-R Wheels : EPL tune : Wagner Intercooler
    2002 S4 : Black : Black Leather : 6-Speed : Stage 2+ ...
    2022 Q7 : Mythios Black
    Senior Member Two Rings jmaddr's Avatar
    Jun 19 2013
    United States
    I think this sort of stuff bodes well for piggybacks, at least during the warranty period -or- if you just want bang-for-buck. I had a CW on and been in for three services and while I can't be sure they hooked it up and took a look, I'm comfortable that the risk is less. I'm also comfortable if a powertrain issue occurs while the CW is on, it's my fault and I should pay..I just want to avoid Audi using TD1 as an excuse to avoid anything even remotely powertrain related.
    Jun 20 2011
    2002 Audi S4
    Plano, TX
    Quote Originally Posted by jmaddr View Post
    That's probably a good way to look at it. No doubt Audi/AOA are dickheads when it comes to TD1. Avoiding TD1 (whether it is by successfully flashing back to stock or using a piggyback) will make your life a lot easier for almost any warranty issue that comes up that they should cover regardless of engine tuning. I think the only way Audi/AOA would do any additional digging is if there was some type of major engine related failure. And, if that is the case, it is probably on you and/or your tuner to figure out.
    Jul 16 2012
    Mid-Atlantic
    Does "CW" mean Chipwerke? Thanks!
    2014 S4 - APR Stage 2 - APR CPS - AWE Touring w/ Resonated Downpipes - APR Carbonio Stage 2 Intake - Alu Kreuz - H&R Front and Rear Sways - 034 Inserts - Focal KX165 + Audison Bit4.9 + Audison 4D - Xpel Front End Wrap - Modesta BC-04 Paint Coating - Rayno S9 Tint - R8 Oil Cap - Porsche 911 Coolant Cap - CR15 Strut Tower Brace - Q5 Brembo Brakes - Goodridge Stainless Brake Lines - P3 Gauge (w/ Track Pack)
    My Seller Feedback Thread - http://bit.ly/2vD36PE
    Mar 21 2015
    Yes
    Sep 22 2013
    Had a noise coming from the diff, Audi replaced the whole tranny. (Manual, b8.5 s4)
    Established Member Two Rings S4Drew's Avatar
    Nov 14 2015
    Ft. Worth, TX
    Quote Originally Posted by superswiss View Post
    This is a fantastic picture! Do you have a link where I can find more of these?
    Current;
    2020 GMC Sierra
    Previous;
    2011 B8 S4
    1968 Camaro SS
    2006 Mazda6 5MT
    1994 Buick Skylark
    2002 Mercury Cougar 5MT
    1985 Audi 5000S Turbo
    Apr 18 2014
    Alberta, Canada
    Well they said not to worry about it and sent me on my way. They'll let me know what Audi says about covering it but they didn't seem concerned about letting me drive out, said I could drive it as I normally would.
    Apr 18 2014
    Alberta, Canada
    I'd rather tune during warranty because at least under warranty there's a slight chance (small, yes) that an issue could be covered. If you wait until after warranty you know you have to pay for it and the cost to repair wouldn't be any cheaper because the car is older. The repair cost though would be a higher percentage of the vehicle's value so I'd rather at least have the chance of an issue being covered. I'm an engineer though, we have odd ways of rationalizing things :p
    Jan 07 2013
    Quote Originally Posted by Dardan View Post
    Yeah, that's essentially what I was getting at with my post. Audi can and does replace bolt-on parts to the transmission such as oil pan, filter etc., but they don't rebuild the transmission if the issue is with the internals. Depending on what exactly is leaking in OP's case, he is looking at a new transmission.
    Quote Originally Posted by S4Drew View Post
    https://www.google.com/. Not joking, I just googled it.
    Mar 21 2015
    Heres plenty of great pics for ya
    http://www.vaglinks.com/vaglinks_com...Technology.pdf
    Edit
    Why is this in the S4 threads?
    Apr 18 2014
    Alberta, Canada
    Got the details - says "tech noted center diff seal is leaking oil". Hoping it's just a gasket or hard seal of some sort accessible without too much disassembly.
    Jun 28 2009
    Audi 2012 S4
    San Francisco
    To totally avoid TD1 for a tuned car, invest in a second stock ECU and swap back and forth. Expensive if you want to avoid TD1 but still have a tuned car. :_)
    Veteran Member Four Rings pdqgp's Avatar
    Mar 06 2015
    a 12 Second boat, & Wife's Lincoln
    Columbus, Ohio
    Quote Originally Posted by joew322 View Post
    Anyone here done this? Makes sense but almost sounds too easy.
    2018 Midnight Black Metallic AWD Infiniti Q50S Red Sport | Burger MS JB4 | 395awhp/430awtq
    2018 Ruby Red Metallic Lincoln MK-C Reserve | AWD 2.3l EcoBoost - Wife's
    2014 Brilliant Black S4 | S-Tronic | 187mm APR Stage 2 Dual Pulley & APR TCU Tunes | APR CPS - SOLD
    Veteran Member Four Rings B18b1ex's Avatar
    Jul 02 2004
    FL
    Quote Originally Posted by pdqgp View Post
    I think it not that easy, I think only the dealer can code ECU's to keys and to the Cluster. At least that's what I was told.
    Established Member Two Rings IbisB8.5S4's Avatar
    Sep 09 2015
    2015 Tahoe LTZ, 2008 Silverado
    Mount Vernon, WA
    yeah it's not that easy... your ECU is coded to your VIN, put in a different ECU and your car will go crazy, dealer will know, and you still most DEFINITELY be TD1'ed
    Nov 12 2015
    Here
    Install new transmission, not covered by warranty: $11,321
    Make an already stupid fast car slightly faster: Priceless
    Seriously, I hope they cover it for you.
    Mein ist grau
    Mar 06 2015
    Columbus, Ohio
    Quote Originally Posted by B18b1ex View Post
    Quote Originally Posted by IbisB8.5S4 View Post
    ^^ I didn't think so thus the mild hint of sarcasm when I asked. I did this on a 1999 SC GTP I had modded back in the day but then it was also pretty much the only way to tune them back then
    The way I look at it, it the risks are a roll of the dice. I'm okay with it as I saved $15-20k by not buying an S6 yet I have similar to better power and performance.
    Apr 18 2014
    Alberta, Canada
    Looks like the center diff seal is just a $21 O-ring (ECS price). Here's hoping it's just a worn O-ring and it's right at a flange split-line for quickest access.
    Nov 10 2014
    Apex, NC
    only in dream land
    - - - Updated - - -
    Quote Originally Posted by Race Shooter View Post
    so far *knock on wood* i went for service and wasn't TD1 .. i don't have APR either
    Present:
    2020 Porsche 992S 7MT | Jet Black Metallic | Stock
    2018 Ford F-150 5.0 | Shadow Black | Hellion Twin Turbo..etc
    2018 Suzuki GSX-R 1000R | Black/Blue | FBO
    2015 Audi S5 6MT | Ibis White | EPL Stage 2
    Jul 21 2004
    South Florida
    Hehe, I like this way of looking at it. As more of our cars have big parts that show up on car-part.com you realize there arent that many repairs now that are too hard to swallow. Heck, I'm starting to think about picking up a 2012 model S4 for 25 grand and using it as a fun/mod car and then getting an A8 4.0T to be nice to :)
    Mike
    2018 Audi S5
    Gone-
    Account Terminated Four Rings
    Mar 11 2014
    Dallas/TX
    I had the same issue. Car was flashed to stock before going to the dealer. But it got flagged regardless.
    Sent from my SM-N920P using Tapatalk
    Jul 21 2004
    South Florida
    Quote Originally Posted by agent47 View Post
    Most people are not getting flagged so something unique probably happened. I wonder if the incorrect "revision" of the OEM code got flashed back to stock. There are several versions of the stock file for each ECU box code and not all tuners make sure the exact same version was flashed back. It would not pass a spec v actual if it was not the same version. I know APR now has an automated flash process to make sure the correct stock version of file gets flashed. That was not always the case. I dont know about other tuners.
    There are no "hidden logs" in the spec v actual process or else everyone would be TD1. If AofA wanted to get really sophisticated they could indeed "even record" such events as number of times the car went past the rev limiter, number of times the car exceeded OEM max torque/load values, etc, etc. These wouldnt be wiped doing a standard flash back to stock. Luckily, AofA does not appear to be doing this or else everyone who ever had a tune would be TD1.
    Mike
    2018 Audi S5
    Gone-
    May 17 2012
    Houston, TX
    Sounds like being flagged varies by dealership. I did both - completely remove tune and only switch to stock file and didn't get flagged from either.
    Mar 11 2014
    Dallas/TX
    Quote Originally Posted by bhvrdr View Post
    Mike
    It was a fucked up situation. I had APR dig in and they found the burn logs perfect. All files were flashed exactly the same as they were before the flash (since my car was not connected to the dealership computers for the 25k and 35k service. I got a tune at 22k mi). And the flag disappeared the same day by evening. I or my dealer couldn't find the flag again after running the VIN multiple times.
    Mar 21 2015
    Quote Originally Posted by AKPS4 View Post
    Then you probably didnt get hooked up to the computer? It most likely would auto flag you with that file.
    Jul 21 2004
    South Florida
    You werent hooked up to the network then...they didnt do a GFF on your car.
    They can also manually flag you and then just blame it on AofA if they wanted to be real jerks. You'd likely never know it was them who entered the flag unless they wanted to tell you.
    Mike
    2018 Audi S5
    Gone-
    Veteran Member Four Rings The Fat Kid's Avatar
    Mar 10 2015
    New England
    Someone posted a letter from AoA (I know you are in Canada) stating that warranty work would be covered on a TD1 car if the owner were to flash back to stock. It seemed crazy, I know, but it could be somehow tied to the Magnuson-Moss Warranty Act. I have also read that you can get the TD1 removed for things like intakes and exhausts by throwing the OEM parts back on and bringing it back to the dealer.
    Audi is clearly doing its best to TD1 cars for anything as a way to reject warranty claims.
    Nov 10 2014
    Apex, NC
    Mike
    I was hooked up to the network and my paperwork shows that.. i still didn't get flagged
    Present:
