Results 1 to 28 of 28
Thread: WTB: Test Pipe
    Nov 22 2015
    Hampton Roads
    WTB: Test Pipe
    Let me know what you have for a 1.8TQM!
    Veteran Member Four Rings Turbo_B5's Avatar
    Oct 09 2012
    abunch of useless shit
    Notnomde Atrebla Adanac
    EH F0UR 2001 A4 1.8TqM
    = Parked cause its junk.
    2002 Golf TDI
    = FASTER THEN YOUR B5.
    2018 Suzuki GSX-R750
    2014 Honda Grom
    2013 Golf TDI
    2001 A4 1.8TqM
    1997 A4 1.8TqM SPORT
    @Turbo_B5
    Veteran Member Three Rings Rodgman15's Avatar
    Jan 12 2014
    Fargo, ND
    For real ^^^ Manzo ebay test pipe works great.
    Oct 10 2013
    98 Civic CX Hatch, 2012 CBR250R
    State College PA
    I always thought it put the primary 02 bung in a way where the sensor would hit the manifold.
    Oct 09 2012
    Quote Originally Posted by Davdraco1 View Post
    no it may fuck with the secondary one though. may need to get a 90 bend. w
    2002 Golf TDI
    2014 Honda Grom
    2013 Golf TDI
    2001 A4 1.8TqM
    @Turbo_B5
    Oct 10 2013
    State College PA
    Delete that SOB! But seriously, great "inexpensive" alternative.
    Jan 12 2014
    Fargo, ND
    Now that it's mentioned, I did Dremel away a bit of material for clearance for one of the o2 sensors, but definitely nothing serious.
    Veteran Member Three Rings HUFset's Avatar
    May 08 2014
    B5 A4 GTRS, MK4 Jetta F21T
    CLFX, Denver
    WTB: Test Pipe
    Quote Originally Posted by Rodgman15 View Post
    Manzo test pipes are garbage and don't fit. Don't waste your time, you'll regret it. The front O2 sensor rarely clears the exhaust manifold, if ever. You can even see in @king_ pic that the front bung sits right in the middle. It needs to be offset to the left, away from the engine. There is a better one sold on ebay by superspeedworldshop and superstreetparts it has the offset front O2 bung that will clear the exhaust manifold and is nearly identical to 034's test pipe. I have bought Manzo and these. This one works correctly and fits. I bought the $72.99 one from superstreetparts but the other looks to be exactly the same and cheaper. It's your choice. Oh don't worry about it saying B6 it will fit B5 1.8T.
    http://www.ebay.com/ulk/itm/231307709848
    http://www.ebay.com/ulk/itm/141844781605
    2000 A4 1.8TQM|GTRS Elim|550cc Maestro|034 AEM WMI|ECS RA4|Carbonio CAI|034/Borla TBE|CTS FMIC|2.0T/AWP harness|Toy Guy/JHM duo SS|034 mounts|034 CAs/Links|ST Coilovers|A6 Strut Brace|ECS RDiff Mount|Apikol Rear Diff Bushings|A4 Sport Cloths|Euro S3 FBMFSW|B6 S4 Rearview|Euro Bolster|All S4 Interior/Exterior Bits|Sport Mirrors/Trim|M3 Spoiler|Aero Arm Wipers|OEM Votex Rack and A4 Bra|A8 Fat Fives|S4 Cluster|P3 VIDI Gauge|Pioneer AVH-X4700BS|Alpine PDX-V9|6 Polk DB Mids|Eclipse 12"
    May 08 2014
    CLFX, Denver
    You can't delete the front O2 sensor, only the rear.
    Oct 10 2013
    State College PA
    I was referring to the rear sensor.
    Oct 09 2012
    WTB: Test Pipe
    This manzo pipe is on its 3rd car. First was a stage 5 build.
    Sent from my Jailbroken iPhone 6s 9.0.2 using Tapashit
    2002 Golf TDI
    2014 Honda Grom
    2013 Golf TDI
    2001 A4 1.8TqM
    @Turbo_B5
    Sep 25 2015
    Shakopee, MN
    Does anyone know if I will have O2 sensor reading issues if I put the primary sensor and connector into the secondary location? I have my secondary coded out.
    Oct 09 2012
    Quote Originally Posted by Tien View Post
    I was just wondering that.
    2002 Golf TDI
    2014 Honda Grom
    2013 Golf TDI
    2001 A4 1.8TqM
    @Turbo_B5
    Veteran Member Four Rings melomandn's Avatar
    Nov 08 2010
    958 CTT, 996 C4S, old motorcycles
    Upstate New York
    Quote Originally Posted by King_ View Post
    Not sure if serious
    Skip the ebay crap, I still have my ATP 3" test pipe in a box somewhere if you're interested.
    - B7 avant, 3.0t swapped
    - B8 S4, Stage 2+
    - B6 S4, not stock
    - B5 S4 Clone, built motor, 2871r
    Oct 09 2012
    Quote Originally Posted by melomandn View Post
    Not sure if serious
    I am serious It was on waterboys stage 5 build before he parted it and fell off the fourms.
    2002 Golf TDI
    2014 Honda Grom
    2013 Golf TDI
    2001 A4 1.8TqM
    @Turbo_B5
    Nov 22 2015
    Hampton Roads
    How much?
    Oct 09 2012
    Quote Originally Posted by BeautifulAudi View Post
    How much?
    treefiddy?
    2002 Golf TDI
    2014 Honda Grom
    2013 Golf TDI
    2001 A4 1.8TqM
    @Turbo_B5
    May 08 2014
    CLFX, Denver
    Your car will run like shit. It is supposed to read EGTs etc from directly after the turbo.
    May 08 2014
    CLFX, Denver
    WTB: Test Pipe
    Exactly, right in the middle and dangerously close to the exhaust manifold. Their QC is crap, could easily come offset towards the engine instead of away. I've had one that didn't fit before. Stick with the slightly more expensive stuff I linked. Then if you upgrade your exhaust mani for a bigger turbo you won't need a new one and you won't have to worry about fitment right now.
    Sep 25 2015
    Shakopee, MN
    Quote Originally Posted by HUFset View Post
    Is that just a turbo or VAG thing? I have seen countless post on other forums where people place it in a different location. Its just crazy that the maybe 6" matters that much.
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    This guy doesn't know what he is talking about.
    o2 sensors do not read EGT's, they read air/fuel ratios.
    Secondly, *if you are running catless* you can put the primary o2 sensor wherever the hell you want as long as there are no exhaust leaks before it. If you are running a cat, it HAS to be before the catalyst.
    2020 SQ7- Wife's ride
    2000 S4- Working?
    Oct 09 2012
    Good to hear redline
    What would happen if i put the o2s backwards?
    This?
    2002 Golf TDI
    2014 Honda Grom
    2013 Golf TDI
    2001 A4 1.8TqM
    @Turbo_B5
    May 08 2014
    CLFX, Denver
    Quote Originally Posted by redline380 View Post
    I don't know why I said EGT. It was early in the AM. However, it seems that AF ratios are better read closer to the turbo in the stock location. Before readings become biased in the exhaust stream.
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    Tell that to Dyno tuners who clip an o2 sensor at the tail pipe to get their readings
    2000 S4- Working?
    May 08 2014
    CLFX, Denver
    Still easier to use a sensor in a bung rather than plugging it. Whatever. The manzo tp is shit.
    Oct 09 2012
    says the guy who doesn't run one. When I get a high flow manifold il just move the o2 to the rear location.
    2002 Golf TDI
    2014 Honda Grom
    2013 Golf TDI
    2001 A4 1.8TqM
    @Turbo_B5
    May 08 2014
    CLFX, Denver
    WTB: Test Pipe
    Says the guy with that engine bay.
    I've owned two. One fit the other didn't. They are shit. I gave an easy alternative that's still cheap.
    Sep 25 2015
    Shakopee, MN
    Exactly what I thought. Thank you
