Results 1 to 6 of 6
    Apr 26 2004
    Raleigh
    Throttle Lag and TSB's?
    Hello Everyone, I posted this thread over on Audiworld but I wanted to see if anyone has any experience with it? I have a 2013 S6 with the hesitation when trying to accelerate typically from a slow roll when turning. It isn't boost lag and there is a long thread about it on Audiworld that is like 19 pages. I am being told I have version 13 ECU/TCU but it still occurs. There is a TSB for this problem 2035235/2 that seems to have resolved most everyone's issues however I'm being told it doesn't apply to my issues since I have the latest TCU/ECU software. Any ideas?
    http://www.audiworld.com/forums/s6-c...e-lag-2895246/
    13 S6
    01 S4 (Gone)
    Oct 16 2014
    South FL
    The TSB you reference applies to all 2013 S6 and S7 models, as well as all 2013 and 2014 A8 and S8 models. It doesn't specifically mention throttle lag, but rather the following 4 items:
    ** Begin quote **
    • The customer reports that the engine warning light illuminates sporadically (Figure 1).
    • The engine may have reduced performance without significant loss of power or stalling.
    • Noise is heard coming from the engine compartment, specifically from the High Pressure Fuel Pumps 2.
    • The following DTCs are stored in the engine control module (ECM), J623 (address word01):
    • DTC P008800 (fuel, rail/system pressure too high)
    • DTC P01C900 (fuel, rail/system pressure bank 2 too high)
    Technical Background
    The fuel metering valve of the high-pressure fuel pump is controlled by a specific on/off ratio. If there is a low system voltage, the on/off ratio may not be enough to keep the fuel metering valve constant in all areas. In such a situation, the fuel metering valve is deactivated and the high-pressure fuel pump switches to full supply mode. Because the increased rail pressure does not match the respective driving situation, the DTC appears.
    ** End quote **
    The solution described in the TSB is to update the ECM software on the S6/S7 from the current version (up to version 0006) to version 0007 or higher. Successive ECM software updates are cumulative, so if you're currently running version 0013 then your ECM already contains all of the changes up to version 0012, plus whatever changes were made to make it 0013. I don't know if 0013 is the absolute latest version, though.
    My '13 S6 is running version 0002 and I can readily replicate the lag and though I still don't like it, I've admittedly gotten used to it. I followed the lag threads pretty closely several months ago, and people reported varying success with the different updates. I seem to recall a handful of people saying they got a TCU update as well.
    Apr 26 2004
    Raleigh
    Thanks good to know. Hmm I was hoping to get rid of it and figured it was just a matter of this TSB but sounds like it must be more complex...very aggravating but yes I adjust my driving to reduce the affects of it. I was told that I had the latest version of both ECU and TCU v13. So I guess I am just stuck with it :(
    13 S6
    01 S4 (Gone)
    Apr 26 2004
    Raleigh
    FYI, I got my car back and checked with VAG and they had upgraded my TCU to v 13 however my ECU was v06. I took it back this morning and asked they flash the ECU per the TSB and sure enough I can no longer reproduce the issue...I have only driven it for a few hours but I could reproduce it pretty easily. I think the issue was resolved by the TSB 2035235/2 even though the description isn't exact. Also don't trust that your dealer has flashed both TCU and ECU to the latest versions....Anyways I just wanted to post this in case it helps someone else.
    13 S6
    01 S4 (Gone)
    Oct 16 2014
    South FL
    Great news!
    What software version is the ECU running now? 0008?
    Apr 26 2004
    Raleigh
    Yes correct..0008
