Results 1 to 2 of 2
    Jan 26 2016
    Netherlands
    Boost Leak Test DIY?
    Hello everyone i'm new owner of a B7 2.0T. I have low boost and need to check for boost leaks. Any idea how it's done on 2.0t?
    Active Member One Ring vtailalaska's Avatar
    Dec 22 2015
    chugiak alaska
    Do a search for turbo leak 2.0T I made a tester out of ABS plastic with a air fitting in the end, took hose off air filter and put about 20psi into the system found the leak in 10 sec. search will show pics on how to make the tester. I have a B6 A4 so intake mite be different.
