Results 1 to 11 of 11
    Mar 28 2015
    Jamaica/ New York City
    Post Help! Red Brake Light Constantly Flashing
    My 2004 A4 Avant quattro's 6MT red brake light has been flashing ever since i bought the car, previous owners said it was front brake pads, after i changed all 4 brakes pads and rotors it didn't turn off. Then i did some forum researching and people say my brake fluid is low, so i topped it off and still no change. Then i took it to a Volkswagen Audi mechanic and he couldn't solve it either. Some other forums say my battery is going but i dont think so it starts right up every time even in these cold winter mornings in NYC. ive been driving it for about 5 months now it has 170k miles and nothing bad as happened my braking feels fine even hard stops the car is okay, just recently drove it in the blizzard we just had and it was fine but its still constantly flashing all the time. could it be my brake fluid sensor??? Thanks
    Veteran Member Three Rings maurizio's Avatar
    Sep 23 2005
    '09 Pilot
    Lake county, IL
    Just to confirm, this is what you are getting?
    "Are you actually asking that question.. Just don't even post on my thread. why do I need to lie on an Audi forum about me fucking two bitches at once. (not literally) yes i did, you are late to the party.
    and this thread has ran out of gas. I just wanted to tell people about my experience I had 2 nights ago and felt like sharing it with my fellow B6'ers. And I thank the people who didn't hate."
    Veteran Member Three Rings Let it snow's Avatar
    Aug 24 2014
    02 1.8TQ Sport 5 speed, 05 1.8TQ 6 speed
    Vermont
    Was it scanned for codes? If there was none try sticking your finger in the reservoir and gently wiggle the strainer up. This might free up a stuck sensor float.
    Mar 28 2015
    @maurizio No it's the "Brake" light not the abs light
    @Let it snow yes it was scanned and everything was good
    Apr 07 2011
    Was it scanned with VCDS or with a regular OBDII scanner? If it was a regular scanner it won't have access to the ABS module. I could almost guarantee with the brake light flashing there's codes stored in the ABS module.
    Mar 28 2015
    It was scanned with VCDS buy the Volkswagen Audi mechanic he didn't find anything.
    Aug 26 2005
    There is most likely something wrong with the brake fluid level sensor/float circuit. The brake fluid level and the brake hydraulics are not monitored by the OBD II diagnostics, so there won't be any fault codes stored.
    Vorsprung durch Technik
    Mar 28 2015
    So what should I do?
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    Mar 28 2015
    Thanks, i hope this works ill give it a try and see what happens btw where do i buy a new sensor?
    Apr 07 2011
    Never considered the level sensor, first I've heard of one going bad.
    Quote Originally Posted by SubaruAudiGuy View Post
    Click
