    Oct 13 2015
    Scotland
    Bonnet/hood problem - HELP!!
    Gents
    When cleaning my B6 S4, I decided to clean around the engine bay. When I went to close the bonnet/hood, it would not close properly. It is partially closed on the plastic catch that comes out of the grill. It will not close at all when I then press down on the bonnet/hood. The dashboard display is showing it as not being closed. At least it has not failed in the closed position!! Thank goodness for small mercies. Has anyone encountered this problem and how did you fix it? Any comments and suggestions would be much appreciated before it goes into the garage.
    Thanks
    James
    Veteran Member Three Rings DarrenOman's Avatar
    Nov 04 2014
    2009 Gray A3
    California
    Are you sure you haven't left anything in the engine bay or on the side fender rails. Even a piece of engine trim not installed properly will stop the bonnet from closing.
    Senior Member Two Rings perm2008's Avatar
    Jan 18 2010
    Hartford, ct
    I had the same issue, I just jiggled the release cable a bit and then it closed fine.
    B7 S4 Brilliant Red: Stasis Exhaust, JHM tune, H&R coilovers
    Totaled: B6 S4 Imola: 2.5" Magnaflow, Carbonio Hot air intake
    SOLD: Ebony Pearl B5 1.8tqm APR Stage II 93oct, ST coilovers, 3" Downpipe, K&N Conefilter, APR 3" TIP, 2.0 Red Coils with 034 adapters
    Totaled: Silvaro B5 front Trak Stock
    Oct 13 2015
    Scotland
    Quote Originally Posted by perm2008 View Post
    Thanks, will try this tomorrow when I'm off.
    Veteran Member Three Rings IslandHydro's Avatar
    Nov 29 2008
    WA State
    You may have brushed the latch under the hood, causing it to (partially?) close. And since it's closed, the hood cant close. If so, pulling the hood release (as previously mentioned) should fix.
