Results 1 to 4 of 4
    Established Member Two Rings wrighttool's Avatar
    Nov 12 2009
    s30
    san diego/ca
    Are you ready to go E85? Stage 3 ECU GIAC fully loaded 91/e85 - No Longer Available
    If you're like me the answer is yes stage 3 e85 is amazing. E85 is like race gas at the pump but unfortunately it's not every where which is why I used this setup. You can freely switch between 91 and E85 at any time no computers needed or for added security used valet (limited power) or kill mode so no one can start your car but you.
    Is E85 worth it ask anyone using it, it's surprising how much faster it is.
    For 6 speed manual b5 s4 stg3
    Includes:
    ECU
    GIAC fully loaded stage 3 91, e85 ,kill ,valet ,multiple boost levels
    Flash loader
    6x Injectors green top
    user guide
    you need to upgrade your fuel pump for this mod (044 pump,Walbro,etc..) and run an 85mm Hitachi maf
    if you need a Hitachi maf I have one for sale $70
    List Date: 1/26/2016
    For more info, click here to view the original listing: Are you ready to go E85? Stage 3 ECU GIAC fully loaded 91/e85
    This item is no longer available.
    Established Member Two Rings manimal's Avatar
    Feb 26 2014
    2016 435xi coming soon for daily duties
    Minneapolis, MN
    Do you need to have rods to run e85 with this ecu? or does this limit torque onset to protect a stock engine? also what boost does it run on the 91 tune?
    Active Member Four Rings aysix's Avatar
    Feb 06 2012
    Las Vegas
    Green top injectors w/e85? Those must be maxed out at like 18 psi.
    Established Member Two Rings verstappen's Avatar
    May 05 2014
    B5 S4, B6 S4, B8.5 A4, 11 Audi Q5
    Phoenix
    still available?
    With your mind power, your determination, your instinct, and the experience as well, you can fly very high.
    -Ayrton Senna
