Results 1 to 2 of 2
    Active Member Two Rings Lmdriver8's Avatar
    Mar 20 2014
    Memphis
    Low beams not working
    Hello, the other night I came out of work and my headlights wouldn't come on, the markers came on and the high beams will work. Also the fog lights will come on. I replaced the headlight switch on the dash and it's still the same. I found a post about this issue from a year ago but there was no post of a solution and other post about a similar is sure was from older models. Those pointed to the high/low beam/indicator switch. I was wondering if this could be the problem. Any help would be greatly appreciated.
    Junior Member Two Rings
    Jul 09 2008
    Colorado
    Can you link the post you are referencing? Dealing with a somewhat similar issue, first my left dipped went out and a week later now my right dipped is out. Hopefully we can get this figured out!
