I see all the SAC threads on here and I'm glad someone figured out that you can drill a hole to reset it lol. Here are my symthoms... At first the clutch would stick to the floor if I did a high rpm shift, wether in boost or not. I assumed my clutch master cylinder was going out as it's the only thing not new since replacing the clutch a few years back. Now the pedal doesn't stick to the floor but gets super stiff and won't disengage the clutch. Before I could pump the clutch up and get it to go into gear now only way to catch a gear was to turn the car over and as it was turning the car would slip into gear. I replaced the clutch master cylinder, and now can get every gear except reverse with the car off. I pretty sure I bled the system properly as I used a power bleeder and the jacked the rear of the car up and manual bled the system. Slave is three years old so maybe it's going bad but I'm not sure. Last bit of info, as I bled the clutch again today I can hear the clutch moving, but before I couldn't hear anything. Next step the slave? Or should I try resetting the sac? Also there's plenty of clamping power, clutch doesn't slip and the pedal is rock hard.
