Results 1 to 40 of 77
    Stage 2 Banner Advertiser Four Rings Arin@APR's Avatar
    Aug 23 2008
    Auburn, AL
    New A4 Quarter Mile Record: [email protected] MPH (APR Stage 3)
    On Sunday, January 24th, we headed to Montgomery Motorsport Park to test our upcoming APR Stage III EFR6758 Turbocharger System in the quarter mile. The car was driven to the track in its currently daily driven form, on street tires, with 93 octane fuel and a full interior, in an effort to show real world results most customers will experience on a day-to-day basis. Several passes were conducted, resulting in record breaking pass after record breaking pass. Ultimately, Trevor@APR, the owner of the vehicle, was able to achieve a [email protected] MPH after cutting a 1.733 60 FT time!
    The fueling system was unmodified, resulting in power limitations below the capabilities of the turbocharger system. Temperature at the track during the record pass was roughly 50F, resulting in a density altitude of roughly -575 feet. Unfortunately, the negative density attitude did not result in a sizable performance benefit compared to running in warmer conditions due the fueling system limitations. However, beneficial to APR customers in warmer climates, the above results are still applicable.
    As temperature drops and air density increases, so does the need for more fuel to satisfied the air fuel ratios prescribed by APR’s calibration experts. To safely prevent the engine from running out of fuel in cooler conditions, APR’s calibration experts have calibrated the ECU to reduce boost pressure while targeting the same power levels. Conversely, during hotter conditions, the ECU increase boost pressure to make up for the loss in air density, ultimately resulting in the similar power output in a wide range of ambient conditions.
    Currently the turbocharger system slated for release in the coming months, which will include full details such as price, power figures, components, application guides, requirements and recommendations. The B8.5 platform, including flex fuel models, is also in development and on employee vehicles at APR and will be releasing around the same time. Fueling upgrades for higher output are being explored.
    Vehicle Details
    -2010 Audi A4 (B8)
    - 2.0 TFSI EA888 Gen 2 engine
    - 6 Speed manual transmission with upgraded clutch and single mass flywheel
    - APR EFR6758 Turbocharger System
    - APR Stage 3 ECU Upgrade, 93 octane
    - APR Intercooler
    - APR Downpipe with 300 cell catalyst
    - APR Catback Exhaust
    - APR Carbon Fiber Intake System
    - OEM 19” wheels with Michelin PSS street tires
    - Full weight (~4,000 LBS with driver and half tank of fuel)
    - Coilover suspension (unmodified from daily street driving setup)
    - Larger front and rear brakes
    - Stock engine internals
    - Stock fueling system
    - Employee owned and daily driven with 90,000 mile
    Go APR!
    GoAPR.com | Facebook | YouTube | Twitter | Instagram
    Phone: (800) 680-7921 Local Phone: +1 (334) 502-5181 Fax: +1 (334) 502-5180
    Address: APR LLC, 4800 US HWY 280 West, Opelika, AL 36801
    Sep 09 2010
    Destin, FL
    Oh man that's nice! I can't wait to see what an upgraded fuel system would do.
    I have a 6 speed AT and this makes me wish I had a MT.
    Veteran Member Four Rings Smellie's Avatar
    Apr 21 2015
    1996 Supercharged Miata
    Penn State University / LI,NY
    Impressive!
    Hopefully it'll break into the 11's with a better fueling system
    2012 B8 A4 | CTS K04/APR 100 oct K04 Tune | 329whp/348wtq | 12.35 @ 110
    AWE "Track" Exhaust | CTS Turbo Downpipe | CTS Test Pipe
    ECS Kohlefaser Intake | Treadstone TR11 FMIC | Snow Performance Stg. 2 Water/Meth
    VMR VB3 19x10 | Airlift Performance 3P
    Established Member Two Rings mahunik's Avatar
    Dec 06 2015
    New York, Clifton Park
    Would a full decat instead of the 300 cell make a difference enough to add on a few more PSI? Could maybe help shave off a half second perhaps.
    Aug 23 2008
    Auburn, AL
    We've seen no difference in power with this cat, compared to no cat, till a bit above 500 HP.
    Apr 29 2010
    victoria bc
    Thats Awesome.....11's with fuel for sure. Sign me up.
    Aug 23 2008
    Auburn, AL
    Quote Originally Posted by Smellie View Post
    I'm sure 11's are possible, even as the car sits. A little weight loss from a lighter driver, and less fuel in the tank may get it there.
    I'm betting a ZF 8 speed transmission or DSG in europe should be able to do it, all else the same.
    A reduction in 60 foot with better tires, would probably get you there.
    Better "track" setup as far as suspension, tire pressure, etc, may do it.
    Higher octane may do it. We ran 93.
    Lastly, weight reduction should get you there (Maybe even with just smaller brakes --- this car had big brakes on the front and rear).
    Apr 29 2010
    victoria bc
    Quote Originally Posted by Arin@APR View Post
    Looking forward to eating some unsuspecting American V8's.....Im not a patient person so this is gonna be hard waiting for it.
    Veteran Member Four Rings hyperunion's Avatar
    Sep 03 2012
    07 Xterra 4X4 , 02 20V Passat variant.
    Lehigh Valley, PA
    Hats off arin.... Impressive time!!... Results I've been asking.. I'm sure zfhp8 will be faster
    Any word on intercooler release?
    B8.5 A4 Premium +, ZF8, APR Stg II+ E85, APR HFC Downpipe, APR Carbon Intake, APR Intercooler, APR T.M. Delete, AWE Quad Exaust, ECS turbo inlet hose, H&R coilovers , H&R F&R Sway Bars, Q5 4 Piston Brembo upgrade, ECS Slotted rotors and stainless lines, OZ Ultraleggeras, Piaa, 3M Crystalline, Xpel Ultimate. IG: "Veritech1"
    RIP: B6 A4 Sport, AWE GIAC rSK04, Bilstein PSS9, OZ SL.
    Senior Member Three Rings NLPed68's Avatar
    Jan 21 2016
    1968 Chevy C10 Restomod, 1974 Bronco Crawler
    Hayden, AL
    Awesome!!! I'm in for one of these too.
    Thanks,\
    Ed
    2012 A4 Avant... APR K04 /c APR tune, B&B catback, 034 HFC, 19" Avante Garde M510's, Bilstein B12 kit, Eurocode F&R swaybars/endlinks, Alu Kreutz, RS4'ish' Grilles, ERON rearview camera, EuroCode FMIC & plumbing, Kohlefaser Luft-Technik intake System, Ross-Tech VAGCOM, R8 coils, S-Line steering wheel /c paddle shifters, S4 F&R brakes /c drilled & slotted rotors/EBC's/stainless lines, LED taillights, Not a Mod, but WeatherTech laserfit floormats, 20% Tint, More to follow
    Established Member Two Rings lostkeyz's Avatar
    May 20 2013
    San Diego
    Arin, will the ecu be tune for launch control in the 6mt. Looks like it from the video.
    Sent from my SAMSUNG-SGH-I537 using Tapatalk
    2013 Audi A4 2.0 TFSI quattro Manual Sedan "never owned an automatic, man tran all day everyday"
    Dec 18 2009
    2015 Jeep Wrangler JKU
    Atlanta, GA
    would love to see that torque curve overlayed on the stock turbo stage 2+ graph. Are the gains across the whole band? Is the best no compromises turbo for the B8?
    2018 Audi S5 SB - Gotland/Rotor
    Previous Cars █
    2010 Audi A4 2.0TQ 6MT
    2008 Audi TT 2.0T S-Line DSG
    2005 VW Jetta GLI 1.8T 6MT
    Aug 23 2008
    Auburn, AL
    Quote Originally Posted by hyperunion View Post
    Production is welding them up now. We're not releasing till they have the quantity we forecasted necessary at the release. I anticipate that will be filled very shortly.
    - - - Updated - - -
    Quote Originally Posted by lostkeyz View Post
    That's the standing limiter with our motorsport hard limiter cut. You'll get it.
    - - - Updated - - -
    Quote Originally Posted by wyld View Post
    When we launch the product, I'll give you a good bit of detailed data.
    Nov 29 2013
    Silver Spring, MD
    Good call.
    2017 BMW F80 M3 | Mineral Grey | BBS FI-R | AWE Non-resonated Exhaust | M Performance HAS | Ceramic Pro
    Gone but not forgotten: 2014 S4| Phantom Black| BBS CI-R Platinum Silver 19 x 9 ET 42 | 3M Crystalline 40 Tint | Opti-Coat Pro | Bilstein Coilovers | SPC UCAs | EuroCode ÜSS Sways/Links | Alu Kreuz | Roc-Euro | 034 Trans Mount | RS5 Front BBK | ECS Street Shield | AWE Touring 102s | AWE ColdFront | RS4 Grille
    Veteran Member Four Rings adamazing's Avatar
    Apr 26 2014
    San Diego, CA
    Quote Originally Posted by ptper View Post
    Good call.
    Yeah, especially how well the reception to the S4 Stage 3 drag results were received by you guys, lol.
    2013 A4 Quattro Green Black Iridescent / APR E85 Stage 2 / AG F421 Polished Copper / Eurocode FMIC + HFC / AWE Quad + CF Diffuser
    build / instagram / flickr
    Apr 29 2010
    victoria bc
    from the graphs that were cobbled together in the 30+ pages of the stage 3 thread it looks like it may be a bit under stock or stage 1 in the first few thousand rpm and then goes way up for the rest of the power band but thats just a best guess given that the graphs had no scale and just some ms paint lines on them. Im interested to see what the final curves look like .
    Nov 29 2013
    Silver Spring, MD
    Quote Originally Posted by adamazing View Post
    Yea, but I'm sure Arin will tell you that it was not their call to gut the car...they only provided the software. Always good to see tuners extend the platforms. Just need to do the cost-benefit analysis. Sorry, I have no idea, but what does a stage 2 B8 A4 run right now?
    Aug 23 2008
    Auburn, AL
    Yeah, it wasn't our product so we didn't care about anything other than the record. I'm sure everyone is well aware of the data I share when I release products we sell.
    Aug 23 2008
    Auburn, AL
    Our calibrators spent a long time doing accurate torque reporting within the ECU. With the work done, it allows for easy control over output. We can limit it wherever we see fit.
    Nov 29 2013
    Silver Spring, MD
    That's cool. Not trying to muck up your thread, so I'll show myself out.
    Apr 19 2014
    Long Island
    I hate to be the downer but why do we need a new thread for this? There is one started in September which was given the same information
    Apr 22 2014
    2018 Q5, 2018 X1
    Sacramento
    I'd say low 13s, Maybe 13.1-13.3 range on a good day. Average maybe mid 13s.
    2018 Q5 Tech Premium Plus
    2011 A4 JHM K04-R : JH MOTORSPORTS TUNED : CTS : 034 : ECS TUNING : SNOW PERFORMANCE
    Veteran Member Four Rings zcspec's Avatar
    Aug 10 2015
    Need VAG-COM work, IM me
    Orange County
    I applaud APR for putting in the R&D for the ERF kit. I like many, look forward to the completion and release of this kit. As wonderful is the 1/4 ET time, what has impressed me most thus far, is the trap-speed which the APR's setup makes. 115mph+, you're entering into some very exclusive territory; IE, M3/4, 911, DB7/8 just to name a few. From what Arin has mentioned, it seems as those this kit to go faster with the additional fuel. Keep on plugging away APR.
    Nov 29 2013
    Silver Spring, MD
    Quote Originally Posted by shaunm82 View Post
    Thanks. I guess cost will be key!
    Apr 01 2011
    B5 on jack stands
    charlotte
    Wow! Very impressive
    powered by
    Hot Boi parts
    Veteran Member Three Rings B44's Avatar
    Oct 27 2014
    Will this be reliable on a 2009 b8 with 6 speed automatic trans?
    Senior Member Three Rings B7AudiSline's Avatar
    Jul 14 2012
    Eastern Shore,MD
    Well done, I think you can squeeze a high 11 sec pass.......
    2012 B8 Quattro Prestige S-line/Black Optic PKG/Phantom Black Pearl/VCDS/TINTS/APR HFC W/3inch downpipe/Kohlefaser Luft-Technik Intake System/Turbo inlet hose/APR Stg 2/R8 Coil Packs/
    Luft-Technik Intercooler w/hard pipes
    RIP 2007 BB A4 2.0T Quattro Tip S-line Titanium Pgk/APR STG 2/Test Pipe/3'' Downpipe/Forge DV/K&N Drop in Filter/VAGCOM/APR Snub Mount/ECS Vent Pod Boost Gauge/CC/HOEN Fogs/LED City Lights/ECS LED Plate Lights/Tint/RIP
    Veteran Member Three Rings 2010b8a4apr2's Avatar
    Jul 31 2013
    navarre fl
    Arin- Thank you for a tease. This is awesome. Def MK5 Golf R Stage 3/MK6 Golf R/S3 Stage1/2 Territory. Extremely happy. I'm sure we will see 11's someday. Especially since Golf R stage 3 kits have fuel upgrades. Not sure what you guys recorded for K04 upgrade but I've seen mid to upper 12s, So if we can shave a second off that, that's awesome. No 10 sec car, but still out of a 4 cyl, amazing. Cant wait to see pics......
    2010 Audi A4 Quattro Prestige 290awhp/315awtq
    Veteran Member Three Rings Jacon's Avatar
    Jan 05 2009
    B8 A4 6MT P+
    Ft Worth TX
    This is shy of amazing. This is a heavy car and to get that much power from a 2.0 is nothing short of astonishing!
    I'd be really proud to have a set up like this and it adds a 'dagree' of advancement for those wanting to add fuel. This can get to 11s.
    My current rides...
    Audi
    Jetta
    Veteran Member Four Rings poweredbyaudi7's Avatar
    Dec 19 2006
    996TT
    San Antonio, TX
    For comparison to the fastest 6MT S4s...
    Code:
    YYMMDD - Time@MPH      - 60FT -  DA FT -Trans- Tune           - Fuel       - User           - Cert - Time Slip - Video
    140223 - [email protected] - 1.74 -   -210 - 6MT - GIAC S2  104 - 104 AKI      - Auditude2.0T    - NHRA - NO TIME SLIP
    151117 - [email protected] - 1.75 -   -800 - 6MT - Uni  S2+ E85 -  93 AKI E85  - DGVR6           - NHRA - Slip
    130309 - [email protected] - 1.82 -        - 6MT - REVO S1  100 - 110 AKI      - El Romano       - IHRA - Slip
    130325 - [email protected] - 1.79 -        - 6MT - GIAC S2   93 -  93 AKI      - Auditude2.0T   - NHRA - Slip
    160124 - [email protected] – 1.733   -575   -6MT  -APR  S3   93 -  93 AKI       -APR
    141024 - [email protected] - 1.78    +150  - 6MT - GIAC S2   93 -  93 AKI      - d.p            - NHRA - Slip
    '14 A4 Q6MT / APR KO4 / AWE / HRE / H&R / 034 Motorsports / P3cars / JHM
    Veteran Member Four Rings blbroo's Avatar
    Oct 26 2012
    SQ5, Nissan D21, 435i Gone: K04'd B8 A4, M235i, UrS6, B9 SQ5, D21 Nissan 4X4
    St. Louis, MO
    Quote Originally Posted by poweredbyaudi7 View Post
    Code:
    And nearly identical on 93 octane. The better times are 104 and E85.
    Sounds like he pegged the rev limiter then popped the clutch? If I try to launch my stock clutch, I spin it through 2nd gear (learned that once and haven't tried a hard launch again).
    Collector of German things.
    “Whoever said laughter is the best medicine had clearly never tasted scotch.”
    Dec 19 2006
    996TT
    San Antonio, TX
    Quote Originally Posted by blbroo View Post
    Indeed. This is really getting me pretty excited about it all. Interested to see numbers and potentially the other times ran...
    Aug 23 2008
    Auburn, AL
    Quote Originally Posted by B44 View Post
    We haven't tested the 6 speed automatic trans. We can, however, limit peak torque.
    Sep 09 2010
    Destin, FL
    This, it has me wondering how much torque we will lose.
    Apr 19 2014
    Long Island
    Quote Originally Posted by The Infiltrator View Post
    Putting the cart way before the horse. They aren't even releasing offical specs
    Senior Member Two Rings KompressorLOgic's Avatar
    Aug 15 2013
    93 Mazda Rx7
    Puyallup,WA
    impressive! yeah ive got the 6at too.... curious what the power figure for it ends up being
    17 Audi A4 P+ ,Daytona Grey, Sport+,6sp manual,034 dynamic+ springs and sway bar,
    10' Audi A4 2.0T P+ Meteor Grey APR stg2, HFC, TDI IC, solo-werks S1
    Sep 09 2010
    Destin, FL
    Quote Originally Posted by homelessNY_LI View Post
    Yeah well, I don't think it would be much but we will see.
    Apr 19 2014
    Long Island
    I agree but let's see what it is when they give offical information hopefully in the next month or so
    Sep 09 2010
    Destin, FL
    What I really want to see is the price with tune, EFR, fuel injectors, and pump. Plus I plan on getting a different intake manifold. This is going to be an expensive upgrade and I can't wait to see the numbers from APR. Searching around still for the best price and power.
    Apr 19 2014
    Long Island
    Maybe we will get lucky and it will be out for November and we can get black friday pricing lol
