Results 1 to 32 of 32
    Veteran Member Three Rings 1thenaton1's Avatar
    May 13 2010
    ^, Q7 TDI
    SLC
    Allroad struts - static
    Previous owner of my 01 Allroad converted the suspension to static. Springs and struts are both red, but don't have receipts or any additional info really on the conversion. The struts are pretty beat and starting to leak. I also dislike that the rear sits a bit lower than the front, pic below.
    I'm lookig for replacement struts to use with these springs. Honestly looking for a cheap, comfortable option - Allroad is built for comfort, I've got a Stage 3 S4 for speed. Can anybody recommend a set of struts to use here? p/n or links appreciated.
    Thanks
    I believe the red shocks and struts are from the stock "sport" suspension setup.
    Using Tapatalk
    Established Member Two Rings CAL4.2's Avatar
    May 21 2014
    2001 Mustang GT 5-Speed
    My OEM sport shocks and struts are red, so that's probably what they are. Cheap / comfortable option would be Bilstein OE Replacements (B4 designation). Koni SRT dampers are also pretty cheap, but some don't like the dampening characteristics.
    Current:
    FOR SALE '02 Audi A6 4.2Q Tip (98k mi) Sport & Prem Packs, 18z 6Piston Fr Brakes|Bilstein|RS6 18x8 ET35|A/S 245/40|Gruvenparts)
    '01 Ford Mustang GT 5-Speed (135k miles):Coilovers & stuff (Bilstein|Stoptech|Porterfield|Maximum Motorsports|FordRacing|Michelin PSS)
    '03 Honda S2000:Totaled
    '05 Honda S2000:Sold
    May 13 2010
    ^, Q7 TDI
    SLC
    Thanks. Should I be looking at Bilstein B4 shocks that would fit an A6 Avant, similar vintage?
    Thought i'd catch shit for identifying the suspension as "uh red" but glad it helped.
    Any other options worth a look?
    http://www.blauparts.com/proddetail....od=MGR2001%2DA here is a complete kit for the conversion, you can order just the shocks/struts if that's all you need. This is just the first place I found a complete conversion kit but I know there are other companies out there.
    Using Tapatalk
    May 13 2010
    ^, Q7 TDI
    SLC
    I got i touch with Blauparts and they will not sell replacement struts, only the complete kit. Thx for the idea tho
    May 13 2010
    ^, Q7 TDI
    SLC
    bump
    Jun 10 2013
    United States
    B4 structs from any C5 should fit. I believe there are spacers in the front. If you remove those the front will lower and be closer in height to the rear.
    May 13 2010
    ^, Q7 TDI
    SLC
    FWIW I took this apart and the "red" kit is actually a strutmasters conversion kit http://bit.ly/1LF812S . Eibach springs and strutmasters struts. I am having the rear springs lenthened 1.25 inches to fix the rake, and have the B4 Bilsteins on order. Hopefully they fit, will confirm
    Dec 16 2014
    Irvine, CA
    if you swap to A6 uprights and pull all the spacers out and use A6 shocks and springs can you get the front and rear even? Everyone who does the conversion without coilovers I see the rear just as low.
    Feb 07 2008
    The boonies, near Seattle
    On my last Allroad I evened the rake by doing eibach sport springs in the front only.
    Picture is a6 sport suspension, control arms etc, eibach said in front.
    -dre
    Dec 16 2014
    Irvine, CA
    Too low for me. I want Level 1 or slightly below and even front and rear.
    Feb 15 2016
    gilboa new york
    Looks good
    - - - Updated - - -
    Quote Originally Posted by 518_woodman View Post
    Looks good
    8520
    May 13 2010
    ^, Q7 TDI
    SLC
    Well a lesson for all I guess, don't listen to free advice on the interwebs.
    C5 bilstein struts DO NOT fit, as a replacement for the Strutmasters kit. Strutmasters "limited lifetime warranty" has so far been useless in replacing these blown struts. Here is some information that hopefully may be helpful for others.
    The Strutmasters kit, linked above, uses Eibach springs and KYB Struts - rear p/n is 341205. These are OE replacement for a C4 95-97 A6 avant
    Should be buttoned up on Monday.
    Jun 10 2013
    United States
    What is the ride height of this kit?
    Jun 10 2013
    United States
    Quote Originally Posted by 1thenaton1 View Post
    When I mentioned C5 struts i assumed you had A6 sport suspension which has red shocks. Didn't know at the time that you that these strutmaster retrofits. Now I'm interested in them....
    May 13 2010
    ^, Q7 TDI
    SLC
    All good, my error in assuming it was a a6 kit. Honestly glad it's not, not looking for low, looking for a functional ski wagon stance. Height is around 27.25 in the front and 28 in the rear, or should be once all set w the spring extension.
    Sent from my SCH-I545 using Tapatalk
    Jun 10 2013
    United States
    How are you getting the spring lengthened? Are you replacing the front shocks as well?
    May 13 2010
    ^, Q7 TDI
    SLC
    I took them to a specialty spring shop where they heat them up and lengthen them. Apparently it maintains the same spring rate but they are able to reset the length through heating treating and cooling
    Jun 10 2013
    United States
    How did you get the KYB part numbers? Did you get the front as well?
    I wonder why it is lower in the back. I got the contact info for one of their techs and I am calling on Monday. I really want a static solution that sits around Level 1. This seems like the ticket.
    May 13 2010
    ^, Q7 TDI
    SLC
    I pulled the strut masters sticker off the shock and low and behold, a kyb p/n. Tech told me he didn't have the part number, BS.
    Looks like you should be taking a look at this, arnott, and blausport conversions
    Jun 10 2013
    United States
    The Arnott and Blausport conversions sit at level 2. They also do not use off the shelf struts. I want something that sits at level 1 and I can maintain over time.
    When are your springs coming back?
    Sep 11 2009
    NE
    http://www.ssautochrome.com/level.itml/icOid/2601 A6 model on allroad will get you L0 to L4 adjustability.,
    Dec 16 2014
    Irvine, CA
    Quote Originally Posted by julex View Post
    I saw review of them leaking in less than 6 months. They also don't sell the cartridges, so you can't rebuild them easy. I'd buy BC racing ones at least those can be rebuilt.
    Sep 11 2009
    NE
    yeah, you sure of that? Because from pictures they certainly look like identical custom parts like XS ones. or perhaps we thing of them as custom but in reality they're just some catalog shocks you can get from your favorite chinese factory.
    Dec 16 2014
    Irvine, CA
    BC are made in Taiwan, but BC has a real presence here in the states, they are still cheap coilovers, but at least you can get support for them. They look similar, but not the same. BC don't use helper spring.
    Sep 11 2009
    NE
    XS power, besides the prototype pic above, doesn't use helper spring either. Believe me that you'd not tell them apart if they were painted the same color . And even funnier is that XS power/Autochrom is actually american company with all their crapo made in China, like everything these days,.
    Jun 10 2013
    United States
    I had considered the FTG coilovers but thought they weren't an option when FTG disappeared. I have since realized (last week) that the FTG coilovers are made by XS Power and still available. However, after the FTG fiasco, now I question the validity of XS power as an organization. Julex, I know you are running them and are pretty happy with them. I can't make up my mind.
    I thought the BC coilovers needed to be lengthened to get level 1 on an Allroad.
    Sep 11 2009
    NE
    Quote Originally Posted by glennda5id View Post
    FTG decided to not pay them for merchandise and thus why the whole commotion. XS power makes a lot of stuff, cheaply, with good enough quality to not fall apart in 5 minutes but it is still cheap stuff. They give 5y warranty I believe still.
    If you lengthen shock then you're limiting your low range, that is you raise the minimum height you can set shocks to. With about 4" of travel of the shock tube, which translates to about 6" on front chock and 8" on rear shock of effective adjustment, you can see that it is hardly of any need to have any longer shock since what's the point of being able to lower only to L2 while able to rise it to L10?
    Normally you lengthen the shock to move its working range higher up. Hardly a need on allroad. Fact is that vast majority of people who buy coilovers are not L3-L4 all time riders, these will never remove air. They are L0-L1 riders who want a car with actual working suspension not a bounce wagon that allroad turns into once you lower to L1 or below. And like me, such people don't even care for air since they never move the car out of L0-L1 anyways.
    i know I don't miss air. My car finally drives like on rails and has suspension that works.
    May 13 2010
    ^, Q7 TDI
    SLC
    Well, to wrap this up - i replaced the rear shocks with the KYB p/n listed above, had the rear springs extended 1.25" and here's how she sits now
    Much better IMO for the intended use of ski wagon / road trip mobile.
    Jun 10 2013
    United States
    Looks good. Can you take final measurements front and back? I assume you have stock size tires (225/55-17).
    What kind of cross bars do you have on top?
    May 13 2010
    ^, Q7 TDI
    SLC
    Thanks, I'm digging it. Final measurements 27.5" front 28.25" rear fender to ground. Stock tire size, new blizzaks with full tread.
    Crossbars are ebay whispbars - http://bit.ly/1oQvM31
