Results 1 to 4 of 4
    Jan 25 2016
    Read odometer without key
    Hey everyone,
    Looking at a junkyard 01 B5 S4 and wondering if there is any way I can find out the mileage on the motor without the key. I know on a m3 you could push the odo stalk and get the reading with no keys, wondering if there's anything similar here.
    I've seen I can remove the cluster and power pins 1 and 23 with 12V, and ground 7,9 and 24, which seems to be the best route so far. Is there any way to do this without a bench power supply? Not sure what amperage I would need. I'm thinking a car battery is too much, but any amount of batteries would be too little.
    Appreciate any advice.
    Jul 07 2009
    Alberta, Canada
    Car battery is fine.
    Electronics won't just draw the full current of the supply... unless they're shorting.
    Put a fuse inline if you're worried about it.
    Veteran Member Three Rings insomniacxp1's Avatar
    May 10 2010
    01.5 B5 S4
    Rochester, NY
    If the ecu loom is still intact, take a jump box with you, connect to assumed dead batt, or if batt is missing directly to cables. power on, open door, you'll see the milage.
    01.5 Imola S4. Stage 3 F21's/To much to list
    Jan 25 2016
    Car battery to the pins worked. Thanks guys
