Originally Posted by
Silverarrow240
Already did
good man! I tell people, think about general safety of yourself, passengers, and other cars on the road. if you float too much and lose control on a highway bump... could be disastrous. Definitely worth spending a few hundred $$ extra to mod properly
Let me put it this way. The only difference between an Audi with shortened springs / stock strut setup and a 1990 honda civic with cut springs / stock struts is... well... the cost of the vehicle i suppose. lol!
Smittylube
Has anyone measured the bilsteins against the stock struts length wise? extended and compressed? That would be interesting to see if they would net the same effect with the euro springs height.
I would have to say the SQ never was even stock with 20's was a smooth ride. Sounds like these shocks are slightly softer, but possibly progressive in a way that when you need the shock to perform it is there.
if you lowered your car 2" or so (most of us do) then you are 2" of compression outside the stock strut's equilibrium position (for lack of a better vocabulary).
So even if the b8's are 1" shorter at their "equilibrium position" then they will perform leagues above when it comes to high speed compression and damping especially. 2" may not seem like a lot, but that's like riding with 500 lbs of bricks in your trunk lol
Measuring them, however, won't do you much good. Because fully extended and compressed measurements don't give you a true value for their proper positioning. you would have to look up the manufacturer's "acceptable" ride height metrics, or find some way to map the amount of pressure vs the length of the strut which would be... brutal lol.
