Results 1 to 2 of 2
    Feb 20 2010
    TT225, Touareg, Tiguan, TDI, A3, RS6, Jetta
    Brighton, MI
    Replaced door lock vacuum pump - program key fob?
    Door locks were not working anymore.
    Found shattered carbon disc in vacuum pump.
    Replaced with used pump, locks working now.
    But remote does not work.
    I have only one key/remote. How can I program remote key fob?
    I tried the VAGcom suggestions (car has 35 module, not 46) but don't seem to see the applicable 'settings' (or missing additional keys to perform).
    01 Allroad Tiptronic, TCU tune, mild stg 3 (350 HP) tune (stock injectors) KraftwerkTurbo TM1. Lower, Wider. Custom tip vent pod with Podi
    02 Allroad 6 spd, Kraftwerk Turbo TM6, 750cc, 3" MAF, piggy, FMIC, CM stg 5 (hate). 30 psi at 3600 rpm. Needs stronger rods (coming).
    05 Golf TDI
    Looking for 2001 A4 1.8T quattro manual with blown motor
    www.regulatorfix.com
    www.kraftwerkturbo.com
    Active Member Four Rings DxC's Avatar
    Nov 16 2006
    Boston
    I would get another key and use the 2 key method. Does anyone know the vagcom way and successfully done it?
