Results 1 to 10 of 10
    Feb 06 2013
    WV
    AWM factory head bolts, how much can they handle?
    Getting ready to do an engine overhaul that will eventually have a 6758 efr blowing through her. How much can the factory headbolts handle safely? If the factory bits can do the work I can save a little money which is always nice.
    Thanks
    If you can read this thank a teacher, since its English thank a veteran...
    Audi make a great car, but their heater cores are, well $h!t.....
    Veteran Member Four Rings tar's Avatar
    Jul 07 2009
    B8 S4, Orange B5 Avant
    Socal/IE
    Have always read/been told 400whp for those.
    I would personally do them if it's apart. Will always be people making more power for xxxxxxx miles with no issues but why chance it?
    2011 S4 6mt Black/ Magma/ Carbon
    HRE ff01 | Rotiform ind-t | AWE Touring | P3 | Roc Euro | PLM | Eurocode Sways | Apr Stage 2 | H&R Sport | Q5 ECS Wave F/R | CR15 | AK | Eurocode Inserts | 034 subframe Inserts | Ecs Carbon Diffuser | JHM CP | ECS Short Shifter |
    Apr 09 2011
    Philippines
    I have 454awhp. I use factory bolts for my AEB head.
    No issues for years.
    1997 Audi A4 1.8T Quattro - Stroked to 2.0L, ABA crankshaft, 83mm Wiseco stroker pistons, Comp Turbo CT3-5556, AEM FIC6, 630cc injectors, VR6 Throttle Body, Schrick cams, Supertech valvetrain, IE intake manifold, Treadstone TR11 front mount intercooler, custom 3" stainless steel exhaust, Turbosmart 48mm Progate, Apexi AVCR EBC, Ringer Racing Stage 4 240mm full face clutch kit, Devil's Own Methanol Injection w/ 14 GPH Nozzle, 30 psi of boost.
    Dec 05 2007
    Fwiw, b6 guys have experienced head lift using the victor reinz gasket but not with the elring gasket. Butbsome havent. Its not the power, but the amount of boost.
    Feb 06 2013
    WV
    That's the other thing, it's an aeb head one awm block. I do not believe I will break 400 awhp since it's my daily but I also don't wanna short myself either. I don't want to do this twice either.
    Seerlah do you know anything else on the head lifts? The Victor is nitrile or butyl rubber coated gasket. I wonder if they have the proper roughness average finish (ra) for those gaskets. They require a much smoother finish on the head and they should always be lapped before using them on high hp builds.
    I am probably going run 24 psi on pump 93.
    Veteran Member Four Rings nynoah's Avatar
    Jan 16 2006
    01.5 A4 avant Past cars: 95 S6, 85 Golf II VR6, 2 sciroccos, 92 Corrado VR6, 86 Euro BMW 535 Alpina
    LA CA
    The prices for upgraded hardware on this site are pretty good.
    http://www.eurospecsport.com/product...e-updated.html
    2001.5 black on black avant 5spd, EFR 6758, Pag Parts band manifold, Vibrant GESI High flow CAT, 2.0L 06A, IE intake manifold, built AEB head, 1000cc Boosted Euro Tune, bosch 044, Ringer Racing stage 3 hybrid Organic/Cerametalic 240mm clutch, S4 interior upgrade, full S4 brakes front and rear with lines, 17in OZ Racing Ultraleggera, 034 HD suspension arms, Stern soft mounts, mirimoto bixenon etc. http://www.audizine.com/forum/showth...s-Build-thread
    Feb 06 2013
    WV
    There is a couple eurospec parts I trust. Those are not them.
    Veteran Member Four Rings Avant Nate's Avatar
    Dec 23 2009
    2001 Audi Allroad 6MT,1999 Yukon Denali, 1987 4Runner
    Boulder, CO
    Quote Originally Posted by mykeg6 View Post
    smaller head bolts on the 06a
    99.5 1.8T QMS: GT2860RS .63 T3, PSI T3 Mani, Turbosmart 38mm EWG, Unitronic 415, Forge 007,Treadstone TR18 FMIC, Walbro e85 450, FSI coil conversion, 3" DIY Magnaflow/Dynomax VT exhaust
    Depo ecodes, DDM slim 6000k, VDO boost gauge, PLX AFR, Greddy profec B EBC,
    H&R sport springs, 034 rear sway, 034 rear diff carrier, A8 fronts,18x8 OZ Superleggera
    Next up E85, efr 7163 or gtx3071r?
    01 allroad 2.7t 6mt, GIAC stage 1
    Dec 05 2007
    I have personally held both gaskets in my hand and ran both. Currently running an elring one. After having held both, the elring seems more stout. Hard to explain unless you held both. But mike hood runs the victor reinz one on more power than any of us will ever make and never had an issue. Can't really call it. Just reposting experiences from myself and others.
    Feb 06 2013
    WV
    I appreciate all advice and suggestions. I know cometic uses nitrile layer with shims like Victor reinz.
