Results 1 to 17 of 17
    Jan 24 2016
    DC
    Need Help Figuring out the name of a part
    2008 A4 B7 2.0T
    I am trying to figure out the name of #42 on the diagram. It has something to do with coolant. Thank you for the help in advance.
    http://www.jimellisaudiparts.com/sho...rimLevel=19025
    Senior Member Four Rings JDillon15's Avatar
    Jul 11 2014
    Chicago, IL
    The thermostat?
    Moro 06 A4 Quattro| Totaled
    Silver 06 A4 Quattro | Sold
    Legal Advisory for Mec's Cabinet Dec 2014-Present
    *Advised the shit out of legal situations
    *Succeeded like never before and rose to the top like a phoenix from ashes
    *Can Take a ZJ with a poker face
    Jan 24 2016
    DC
    44 is thermostat, I believe
    Jul 11 2014
    Chicago, IL
    Quote Originally Posted by b7a408 View Post
    No, 42 is the thermostat.
    check here.
    part number: 06D121111G
    I think 44 is a coolant flange.
    Jan 24 2016
    DC
    Quote Originally Posted by JDillon15 View Post
    check here.
    I thought the Coolant Temperature Sensor went with the thermostat back of the engine and coolant flange was in the front. Might be reversed
    Jul 11 2014
    Chicago, IL
    Yeah, revered. The thermostat is on the side of the engine (driver's side) and the coolant flange is on the back with the CTS.
    Jan 24 2016
    DC
    thanks for the help
    Jul 11 2014
    Chicago, IL
    thanks for the help
    No problem.
    If you're looking to replace it, there's some pretty good DIYs on here. I've replaced mine. They're not very difficult.
    Jan 24 2016
    DC
    I've replaced the CTS o-ring before. Currently I have a small leak coming from the thermostat. I'll take a picture and post it. It looks likes a plastic piece of the small pipe cracked.
    Oct 02 2006
    Wadsworth,OH
    Definitely the thermostat.
    Jason
    Jan 24 2016
    DC
    Sad thing is that the thermostat was replaced 3 years ago because it was failing. Here are two pics from this morning:
    http://www.audizine.com/gallery/show...hermo2&cat=558
    http://www.audizine.com/gallery/show...hermo1&cat=558
    Jul 11 2014
    Chicago, IL
    Yeah they are known to go bad. If you have a half-decent set of tools, I highly recommend replacing it yourself. You'll save yourself a ton of money and like I said above, it's really not difficult.
    Jan 24 2016
    DC
    Thanks again. I'll write an update once I decide what to do.
    Jan 24 2016
    DC
    Hello All,
    It's been about a year since I noticed a small coolant leak forming under my car after driving it and letting it sit. During the past year, I bought two gallons of coolant and topped it off (50/50) every few weeks. Here we are a year later and I still can't find where the leak is coming from. I'm at 110,000 miles and it's time to replace the timing belt and water pump. I'd hate to have it done and not get the coolant leak fixed.
    My thermostat works fine (was replaced 30K-40K miles ago). Everything in the front of the engine is dry and around the thermostat is also dry. Around the CTS in the back is also dry. I noticed a small puddle right behind the oil filter on the block. I took it to a mechanic to see if we can find the leak. He pressurized the coolant reservoir tank and lifted up the car but no leaking/dripping. I assume because the car was still hot. I'm attaching few photos of my situation. What is the metal box #43 in the diagram?
    Mar 24 2013
    Oakdale, CT
    #43 is the oil cooler. Check the coolant flange on the back of the head for leakage.
    -Adam
    Veteran Member Four Rings 4rings5stars's Avatar
    Jul 31 2011
    O ring on the thermostat? Not replaced or not seated properly? Common issue
    I did my t-stat 2 years ago and it's had a minor leak ever since. I put less than 5k/yr, so it's never been a priority for me.
    The fleet
    2000 S4 EPL tuned Stage 3 -- Silver/Panda -- Latest fun project
    2002 S4 Avant 6spd -- Nogaro/Silver -- Long term rehab project
    2012 A8L -- Night Blue Pearl/Nougat
    2013 VW Touareg VR6 Lux -- Flint Grey/Black
    2001 BMW 540iA Sport -- Steel Blue/Grey
    2001 BMW 750iL -- Night Blue/Ivory
    2004 Jaguar XJ8 -- British Racing Green/Tan
    2005.5 A4 Avant 6spd -- Quartz/Black -- Sold
    Jan 24 2016
    DC
    Thanks for the replies. I replaced the O ring on the CTS before and checked it this past weekend again. It's all dry. I think another member here suggested oil cooler gasket or coolant gasket...I'll have to look more into this.
