AUDI A3 Boost Gauge 8P TDI P3 Cars Integrated Vent VIDI Gauge Pre-Installed Vent
New, never installed. Comes in original box.
P3 Digital gauges provide the highest level of OEM integration and color match offering more features than any other gauges in their segment. Starting at a price competitive to single feature old-school needle gauges, they offer unmatched feature to price ratio.
All gauge models include an on-the-fly configuration menu for setting units (BAR/PSI for boost, and C/F MPH/KPH for VIDI values), as well as feature options, and ambient calibration. See www.p3cars.com/install for more details.
P3 BOOST GAUGE
Boost and Vacuum with integrated 45psi sensor.
Battery Voltage readings with quick-look and sleep-check.
Optional Auto-Dim or Manual Dimmer
Includes Digital Display, AuxBox w/Sensor, Vac Tubing, Wiring, Wire-taps, Zip-Ties
P3 V.I.D.I.
Boost and Vacuum from OBD2 port
Plug and Play install - just plug into your obd2 port and install into dash!
Optional analog sensor for reading boost on tuned/big turbo cars.
OBD2 Data for Coolant Temp, Intake Air Temp, Exhaust Gas Temp, Throttle Plate, Speed, RPM with Shift-light, Battery voltage and more!
Code Read/Clear
2 x universal 0-5v linear analog inputs
Includes Digital Display, Custom OBD Wire Harness, Control Box.
List Date: 1/24/2016
For more info, click here to view the original listing: AUDI A3 Boost Gauge 8P TDI P3 Cars Integrated Vent VIDI Gauge Pre-Installed Vent
This item is no longer available.
