Results 1 to 6 of 6
    Veteran Member Four Rings Tone-Dogg's Avatar
    May 06 2007
    2020 Q3 P+
    Hartford, Connecticut
    Okay did something stupid, broken tab
    Decided to change my spark plugs in 26 degrees. Upon doing so, I snapped the tab to remove the harness to the coil pack. Thinking I learned my lesson, I proceeded to try another one and snapped a second tab. Anyone know how to remove the plug from the coil pack I know ecs sells a tool for this but in 191k miles at 5k intervals, I have done this several times. Guess they were due to break at some point. Tks gang.
    Sent from my SM-N910V using Tapatalk
    2016 Q5 3.0T Quattro P+ Sline Black Optic
    2020 Q3 2.0T Quattro Premium +
    Veteran Member Four Rings gmudan's Avatar
    May 03 2009
    A4%20B6/B8
    Arizona
    You can stick a very thin screw driver in the other end and pull the connector off.It works kinda like a flap.
    Jun 08 2008
    Calgary AB Canada
    Yup. Small flat head in through the top of the connector
    2011 Audi A4 Avant // quattro // Garnet Red
    Stock. For now...
    1989 Porsche Carrera 4 // 5 Speed // Guards Red
    May 06 2007
    2020 Q3 P+
    Quote Originally Posted by gmudan View Post
    Ah, tks, figured it was something like that but after breaking 2, decided to wait and hear.
    Will give that a shot, so small flat head, I the square slot and then slide the connector off, yes.
    Aug 27 2013
    Philly
    Quote Originally Posted by Tone-Dogg View Post
    I stick tiny flat heads or picks in the side furthest from the thumb clip, and then leave it in there while I am removing the clip. Works every time.
    Sent from my Nexus 6 using Tapatalk
    May 06 2007
    2020 Q3 P+
    Thanks guys, just figured it out. Plugs changed.... have a great wkd
