Results 1 to 20 of 20
    Established Member Two Rings WillB6A4's Avatar
    May 31 2014
    New York
    Depo H7 Ecodes city lights
    Just got my depo ecodes and theres wiring in the housing that is different then the stock ones. Wondering if its for the city lights or something else? And if it is how would i connect it? Thanks
    B6 A4 daily KO4
    Veteran Member Four Rings Willënskraft's Avatar
    Oct 14 2011
    2002 Audi A4 1.8TQ, 2007 Audi A4 2.0TQ
    Norcross, GA
    Yup the ones going into the hi beam reflector is the city lights. There should be a plug with different color wires iirc.
    "Beep beeeep bloop boop" - R2D2
    May 31 2014
    New York
    How do i connect it to stock 10pin harness?
    B6 A4 daily KO4
    Veteran Member Four Rings ZipMeUpJ's Avatar
    Nov 12 2012
    hologram R8
    boston
    You don't. The car harness only connects to the headlight unit on the outside.
    Oct 14 2011
    Norcross, GA
    It's already connected, just need a bulb.
    May 31 2014
    New York
    Theres an additional plug it looks like on these
    May 31 2014
    New York
    It runs into the 10 pin connector
    B6 A4 daily KO4
    May 31 2014
    New York
    Heres a picture
    B6 A4 daily KO4
    Veteran Member Four Rings PreciseD's Avatar
    Feb 05 2014
    That is for the leveling motors. Did you have Xenon headlights before? If so you need to swap them and then rewire that connector.
    ----- My EFR 7670 Build Thread ----- "The thing about quotes on the internet is you can not confirm their validity" - Abraham Lincoln -----
    Oct 14 2011
    Norcross, GA
    Oh that one yup it's for the leveling motor lol.
    Clicky
    May 31 2014
    New York
    Ok good to know. I don't have leveling motors the original headlights were just halogens. So i shouldn't have a problem leaving them disconnected right?
    B6 A4 daily KO4
    Feb 05 2014
    no problem at all
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    This is something that you should really consider as a preventive measure for your Depo housings. It doesn’t take much effort and will eliminate a very common failure point. Clicky click®
    May 31 2014
    New York
    got them all hooked up and work good. Ones already a bit fogged
    B6 A4 daily KO4
    Veteran Member Four Rings fR3ZNO's Avatar
    Feb 09 2013
    WNY
    slight necro bump here, are all B6 E-Code headlights wired for single or dual filament turn signals?
    I figured they had the socket and wiring for single filament, and therefore no parking lights and only turn signals. BUT! according to the description on ECS, the Depo E-Code lights require a euro socket and single filament bulb:
    Does not include bulbs, uses a D1S main beam with a H7 high beam, and requires use of turn signal bulbs es251931 with socket es514019. City light bulb available as es7535.
    ES514019 is the Euro Single Filament Bulb Holder.
    So now I'm confused.
    "If one does not fail at times, then one has not challenged himself." - Ferdinand Porsche
    Mar 02 2015
    miami
    single. it should come with the bulb holder as well, all you have to worry about is the bulb. i just bought a pair of depo off ebay.
    Feb 09 2013
    WNY
    Okay, awesome. Thanks.
    Feb 23 2004
    2004 A4 1.8T Ultrasport 6MQ
    Stow, OH
    As I've also switched over to these headlights, are there any dimensions available for the metal tab? Size of screw? My passenger headlight seems to like to fog up at the sign of oncoming rain/snow. Haha. Want to try to get these water tight as I'm also planning on doing the Bi-Xenon upgrade.
    USP CLUB MEMBER #34
    Dec 28 2006
    Western Maryland
    Quote Originally Posted by CyberPMG View Post
    I'm out of town and my car isn't so I can't measure the tab. I just found a strip of metal that fit between the ribs of the plastic tab and drilled a hole to match the wire clip. I then found a small SS nut and bolt and drilled a hole that matched into the other end of the metal strip and stuck it through the hole.
    Done.
    Feb 23 2004
    Stow, OH
    Done.
    Thanks for the info. Will do some measurements this weekend and get it done!
    USP CLUB MEMBER #34
