Results 1 to 15 of 15
    Active Member Two Rings Mcfly's Avatar
    Jan 18 2016
    2009 Subaru Impreza
    Ottawa, Canada
    Car not starting!!!
    Hey all! My car is not starting. She's a 2012, base model, quattro, 65000kms, stage 2 unitronic with cts turbo turbo back & ecs boost gauge.
    Car is not cranking at all, and battery looks fine, its brand new and everything electronic works fine.
    Please help!!
    Also, and it really shouldn't be a thing, i left the seats down yesterday and when I got in this morning there was some condensation inside...
    Jan 18 2016
    2009 Subaru Impreza
    Ottawa, Canada
    No error symbols. MT
    Jun 26 2009
    Bremerton WA
    Sounds like a possible bad clutch switch. On top of the clutch pedal arm there should be one or two microswitches. You can see if they are adjusted properly. With a meter they should read closed when clutch is depressed.
    VMR 710's, APR software, Eurocode HFC
    Jan 18 2016
    2009 Subaru Impreza
    Ottawa, Canada
    Interesting! I'll try that and get back to you. Thanks!
    Veteran Member Three Rings STA4's Avatar
    Jan 12 2012
    Mississauga, ON, Canada
    Car not starting!!!
    Do you get a click of the starter solenoid along with dimming of interior lights?
    You should scan for codes.
    I had a click, but no crank and it turned out to be a break in the main power harness to starter.
    Peter
    2009 A4 2.0T Quattro Premium 6MT
    Meteor Grey/Black | B&O | STaSIS Tune/Exhaust/Springs/RSB/Wheels | K&N Filter | Eurocode TIH/HFIP/IHK/HFC/Alu Kreuz | GFB DV+ | R8 Coilpacks | Strat O2 Spacer | BFI OCC | Podi Boost Gauge | Rieger Rep Spoiler | RS4 Rep Grille | A4L Foglight Grilles | LED Interior/Puddle/Plate/Signals | Morimoto 5500K HID Foglights
    Veteran Member Four Rings o1turbo30v's Avatar
    Feb 06 2012
    Cars, guns, nuts and bolts
    Allentown, PA
    Try locking then unlocking it, to reset the immobilizer.
    Jan 18 2016
    2009 Subaru Impreza
    Ottawa, Canada
    No, nothing like that. Just silence. Lights are not dimming, everything electric is good to go...
    Veteran Member Four Rings Mr.Audi's Avatar
    Feb 26 2008
    none
    BALTIMORE
    Did u happen to just try an jump it?
    I always would... Just to totally confirm its not that.
    (Just me)
    Can u "hit the starter" as in other older cars.., just a question. Not sure it is possible or good idea lol
    Sent from ....
    B8.5 S-line prestige
    #fourringarmy
    Senior Member Two Rings oshwi's Avatar
    Oct 07 2013
    nutley, nj
    does it happen to be like this?
    https://www.youtube.com/watch?v=fLZQc9SuAc4
    2013 S5 Prestige
    STOCK. for now.....
    Gone: 2010 A4
    Mods: apikol rear diff mount / Zubehör rear diffuser / Unitronic HFC and DP / solo werks / awe boost gauge / carbonio APR intake
    Repairs done: Engine removed to complete repair Piston rings replaced (stage 1 and stage 2 oil consumption fix) / Wheel bearing(s)/hub(s) replaced / Crankshaft pulley/balancer replaced / Timing chain tensioner update
    Veteran Member Four Rings Elliott's Avatar
    Oct 28 2007
    Ocean Beach, CA
    Quote Originally Posted by oshwi View Post
    Aren't these essentially link fuses to keep the battery from short circuiting (during an accident for example)? Would be surprising to see one randomly fail without provocation.
    CEO and General Manager of the AZ Pedal Responce Team
    Sep 24 2014
    2015 Audi Q3 Quattro, 2017 Corvette M7 Grand Sport, 2017 Audi SQ5, 2019 Porsche Macan, 24 Jetta GLI
    Central NJ
    Quote Originally Posted by van462 View Post
    There are no microswitches on the pedal mechanism, they are integrated into the clutch master cylinder.
    Sep 24 2014
    Central NJ
    Jun 26 2009
    Bremerton WA
    That has to one of the better technical threads I have seen on this forum.
    Sep 24 2014
    Central NJ
    What...you don't like all the "my tint....", and "which wheel?.." and "which tune?...." posts???
    Jan 18 2016
    2009 Subaru Impreza
    Ottawa, Canada
    So the next day the car started after two attempts. Brought it to the shop and the scan indicated a starter relay malfunction.
    No idea wtf happened, but it works now. Thanks for the interest though!
