Results 1 to 19 of 19
    Active Member One Ring af1's Avatar
    Feb 23 2014
    2016 Q5 3.0T, 2011 Q5 2.0t
    cle oh
    6MT Idle Question
    For those with the 6MT trans anyone notice an unexplained jump in rpm's while idling?
    Frequently while sitting at a light say clutch in, foot on brake 1st gear the rpm's will increase from the normal 600-700 rpm to 1100-1200 rpm and then go back down. At first I thought I was accidentally depressing accelerator. Not the case. I've tried shutting off climate control thinking it was possibly A/C compressor turning off and on. No change. It does seem however that it will not do this if I idle in neutral with clutch out and foot on brake. Any ideas would be appreciated.
    2016 S4
    2016 Q5 3.0T
    2011 Q5 2.0T
    Feb 23 2014
    cle oh
    Forgot to mention completely stock 2016 with 8000 miles.
    2016 S4
    2016 Q5 3.0T
    2011 Q5 2.0T
    May 03 2008
    Ohio
    Wonder if it's the anti-stall hall effect switch in the clutch master cylinder giving a false positive. Does the car consistently do the rpm bump while letting out the clutch in 1st gear (as it should)?
    Sent from my SM-N910P using Tapatalk
    Feb 23 2014
    cle oh
    Can't say for sure about rpm bump while letting out clutch in 1st gear. I'm usually working throttle while letting clutch out in 1st gear to get moving. Sorry for confusion?
    2016 S4
    2016 Q5 3.0T
    2011 Q5 2.0T
    Jun 05 2015
    Manchester
    Could be any electrical draw that makes the engine idle increase.
    How long is the increase for?
    Veteran Member Four Rings MrFunk's Avatar
    Apr 04 2012
    MSP
    Yes - normal.
    It's the anti stall function. Happens in some instances where the car will intervene and add a bit of throttle when unnecessary.
    Established Member Two Rings S4Drew's Avatar
    Nov 14 2015
    Ft. Worth, TX
    As others have said, the car has an anti-stall feature; if you let the clutch out in 1st gear from an idle, the car will apply light gas to prevent you from stalling. My guess is this is what you are feeling, so either you are letting the clutch out a little bit while you are sitting, or the sensor is way too sensitive.
    I would say if you're going to sit idle somewhere for longer than a few seconds, drop into Neutral and let the clutch out. If you are consistently sitting with your foot on the clutch, you will wear it out early.
    Current;
    2020 GMC Sierra
    Previous;
    2011 B8 S4
    1968 Camaro SS
    2006 Mazda6 5MT
    1994 Buick Skylark
    2002 Mercury Cougar 5MT
    1985 Audi 5000S Turbo
    Apr 04 2012
    MSP
    Quote Originally Posted by S4Drew View Post
    This is good advise... this is how I was taught to drive MT and I've taught a couple new drivers myself and always tell them to do this.
    Established Member Two Rings Sailingtime's Avatar
    Mar 18 2015
    2003 Vw Jetta GLI VR6 BDF Turbo
    NYC ��
    Quote Originally Posted by af1 View Post
    I guess it's normal, I have been to dealer few times with this issues. My car idles extremely uneven in neutral no clutch or brake pedal applied. Audi told me nothing to worry about, it's normal. My engine will hunt 150-250rpm for no apparent reason. It runs great otherwise.
    2015 6Spd Daytona, Tech, Sport Diff, Napa , B&O, Black Ops, Carbon Inlays.
    Feb 23 2014
    cle oh
    Thanks for the feedback.
    I've been driving manuals of various makes and models for 40 years and the only anti-stall feature I was aware of was the driver. This is a new one on me. I guess it makes sense now. As I stated originally it doesn't seem to happen when I let it idle in neutral and clutch out.
    2016 S4
    2016 Q5 3.0T
    2011 Q5 2.0T
    Established Member Two Rings iviegatron's Avatar
    May 15 2015
    Texas
    As others have mentioned, it's normal. Below is a video I recorded when it was happening to me.
    Current Cars: 2014 Audi S4 Ibis White; 2005 Toyota Camry (Daily Driver)
    Previous Cars: 2000 Audi TT, 2006 Audi A4, 2009 Audi A6, 2010 Nissan 370Z, 2011 Mitsubishi Evo X
    Wish List: Lamborghini Huracan, Porsche 911 Turbo S, Nissan GTR, BMW M3/M4
    Jun 05 2015
    Manchester
    Quote Originally Posted by iviegatron View Post
    Your indicator sounds odd in that clip.
    Apr 04 2012
    MSP
    Quote Originally Posted by sebgreen View Post
    Sounds normal to me...
    Veteran Member Four Rings Dr GP's Avatar
    Jun 08 2005
    Lexus RX 350
    SE, PA
    I don't think there is anything actually wrong .
    Veteran Member Three Rings SouthernBoy's Avatar
    Jun 03 2014
    Virginia
    Never noticed this with my 2016 S4. But then, I don't sit at a light waiting for it to change with my foot on the clutch and the transmission in first gear. Not the best thing to do for the release bearing. When I am waiting for a light, my foot is off of the clutch and the transmission is in neutral. Tach displays a steady 700 RPM.
    In the final seconds of your life, just before your killer is about to dispatch you to that great eternal darkness, what would you rather have in your hand? A cell phone or a gun?
    Veteran Member Four Rings schirm's Avatar
    Apr 23 2009
    1999 bmw z3coup M with 5,000 miles Mint
    Forked River nj
    100% normal. Car does the revving in 1st gear for you.
    2004 A4 1.8t | Avant | 6MT | Stock | Atlas gray |
    2010 S4 | Ice Silver Metallic | Sport Diff | 6 speed | 19 5-Tri-Spoke Wheels | Audi Drive Select | B&O | Silver/Black Nappa Sport Seats | Navigation Pkg | Brushed Aluminum Trim | APR Stage 2+ | Hoen Xenonmatch Fogs | 034 Motor mounts | Roc Euro | black RS4 Grille |
    Past
    2007 A4 | Revo Sg 2+
    2005 Subaru Legacy GT 365WHP
    Veteran Member Three Rings eightamrock's Avatar
    Jan 21 2016
    Not sure you need more validation, but I have a '16 with 1280 miles, same thing.
    Auto throttling.
    Veteran Member Four Rings GeoJoe's Avatar
    Jun 08 2012
    2022 Q7, 2018 Q5, 2016 Porsche GT4, Subaru Sambar, Honda Acty Van and a 2018 Tundra Loooooooong bed
    ATL GA
    He's low on blinker fluid.
    May 15 2015
    Texas
    Quote Originally Posted by GeoJoe View Post
    I forgot to top it off before my drive.
