Results 1 to 16 of 16
    Established Member Two Rings Jperez9627's Avatar
    Dec 06 2012
    1999 Honda civic, 2015 Kia soul
    California
    Talking Louder turbo spool I do want
    Ok guys so I want to make my turbo spool louder and I was wondering if routing my "intake" to the wheel well will help me accomplish this. I seen some kits on ebay made by cx racing that basically just add pipe down to the well, my brother in law has a neon srt 4 and when he spools that thing roars. I have also read about the Swiss cheese mod but idk I'm pretty iffy on that one. Any advice or suggestions are welcome. Thanks guys
    Nov 10 2015
    Sudbury, ON
    exhaust & test pipe will help. You can remove the stock airbox all together, and clamp a 3" Cone filter onto your MAF. and add some strapping and ties to keep it rigid. I attached my stock headsheild in car also. Lots shy away from this, as stock airbox performs better, I did it soley for simplified under hood/more room. You hear turbo alot more.
    2004 Audi A4Q 1.8T Ultrasport 6MT
    Frankenturbo'd, Meth, front mount, custom tune, full exhaust, bunch of other crap
    2004 Audi A4 Quattro 1.8T Tip Sport Pkg SOLD
    18" S4 Avus wheels l Eibach Lowering springs l Magnaflow 16601 l 3" TP l Pioneer Double Din l USP Bumper/S4 Door blades/Spoiler l Black on Black
    Veteran Member Three Rings 05A$SE's Avatar
    Feb 12 2008
    05 A4 1.8T Special Edition
    Dirty Jersey / Phoenix
    Gut the stock box, Drop in dry flow filter, test pipe that matches exhaust size and turbo outlet size without steps or changes in size, exhaust, 380cc injectors, DV (Splitter for that woooOOSHH!) tune.
    DONE
    Or get something that actually moves some air and doesn't whistle and you will have more of a turbo sound. the stock turbo is sad, they have hair dryers larger then our stock turbos.
    2005 DG On Black Special Edition 1.8T 6MT
    Built 2.0L Stroker, ETC
    2012 C63 AMG - 600HP and counting
    2006 Corvette - GTR (1 of 7) - Blue One on GOOGLE
    1998 H1 - AM General 4dr Hardtop
    1992 M998 - Slantback Project
    1990 240SX - big turbo drift missile
    1989 K1500 - LQ4 6L90 Swap
    1986 RX7 - Truck conversion, LS1, 72* angle kit
    Dec 06 2012
    California
    Quote Originally Posted by 05A$SE View Post
    DONE
    I already have a stage 1+ Motoza tune with 440cc injectors, test pipe, cone filter, and fmic. The spool is ok, I have a forge hybrid dv. Ur not kidding on those hair dryers lol
    Dec 06 2012
    California
    Quote Originally Posted by jesse500 View Post
    Would a heat shield lower the spool sound? I'm not stock anymore. My next move is a bigger turbo
    Nov 10 2015
    Sudbury, ON
    Quote Originally Posted by Jperez9627 View Post
    no it wouldnt
    Veteran Member Four Rings MacFady's Avatar
    Aug 10 2011
    330i ZHP
    Prince Edward Island
    You still have stock downpipe?
    Dec 06 2012
    California
    I have custom exhaust so no I dont. I have 2.5 inch all the way down
    Feb 23 2004
    2004 A4 1.8T Ultrasport 6MQ
    Stow, OH
    Stick a microphone by the turbo and pipe it through the stereo. Use a BOV, but know the design of the 1.8T for the A4 is best run in a closed loop, so you will trade off performance for noise.
    USP CLUB MEMBER #34
    Feb 12 2008
    Michigan
    Removing the belly pan will give you more engine noise and more turbo noise/bpv sound
    Veteran Member Four Rings BARRY's Avatar
    Nov 02 2007
    SF Bay Area, CA
    i have dry high flow filter, test pipe, and thermal r&d exhaust. my turbo spool is well heard for this dinky turbo. bigger turbo's will have more spoooooling sound.
    Feb 12 2008
    well shit. In that case, You need one of these - ClIcKy Be sure to check the box that says 2871R option, Get 550CC injectors. and call it a day.
    Veteran Member Four Rings gtsingh91's Avatar
    Sep 27 2008
    2005 A4 1.8TQM, 2001 A4 1.8TQM, 2007 350Z
    Long Island, NY
    Noob question, what's the difference between the basic GTRS option compared to the $95 Eliminator2871R Upgrade option? And does this kit really utilize the stock intake manifold or is it highly recommended to upgrade that?
    Instagram: @_vishis
    2001 Audi A4 1.8T Quattro - 5 Speed - Silver
    2005 Audi A4 1.8T Quattro - 6 Speed - Revo Stage II+ - Light Silver Metallic
    2000 Audi S4 2.7TT 6 Speed - EPL Stage II - Hibiscus Red Pearl SOLD
    Feb 12 2008
    Michigan
    They are both eliminator turbos, the rs spools up a little sooner, the 2871 has better top end. From what I gather in older posts is that there is not a whole lot of butt dyno noticeable difference.
    They are designed to fit the stock exhaust manifold, but you really should run a higher flowing manifold, in the least bit, port the stock manifold.
    Apr 01 2007
    1983 Chevy Silverado
    houston texas
    Quote Originally Posted by Fast4esT View Post
    They are called 'elmin' turbos because they eliminate the need for a manifold upgrade. No modification is required. The 71 uses a larger compressor wheel, which stuffed in the same GTRS housing is less efficient and less powerful compared to the GTRS.
    http://www.audizine.com/forum/showth...=1#post4984452
    2019 SQ5 Prestige
    Sep 27 2008
    Long Island, NY
    Quote Originally Posted by texasboy21 View Post
    Thank you! Just what I was looking for. My plans are to stick with Revo (I currently have their Stage 2+ file) and just upgrade the turbo, injectors, and maybe manifold. I'm not planning on maxing this turbo out or anything I'm just looking for an improvement over the K03/K04 turbo. This is my DD.
    Instagram: @_vishis
