Results 1 to 16 of 16
Thread: I Messed up....
    Established Member Two Rings Almost1's Avatar
    Oct 02 2013
    1992 Corrado SLC
    Baltimore
    I Messed up....
    A fun day of playing in the snow ended in tragedy. Could've been a lot worse. Have a look
    This is the rear passenger wheel. Hopefully this is the worst of it. No body damage, but I still haven't jacked it up to look underneath
    The rest of her
    Veteran Member Four Rings ryanhmusic's Avatar
    Aug 05 2014
    jack stands, a power washer, hand tools, bones of my fallen enemies, etc
    did you hit a curb sideways at speed?
    meh it happens. enjoy your $250ish mistake and learn from it...no worries.
    highly doubt anything else was damaged but maybe your lug bolts too I guess?
    I'm living for the day I can park something Italian inside of my house.
    I had one wild summer on match.com. -some jackass
    01100010 01100001 01101110 01100001 01101110 01100001 00001010
    Oct 02 2013
    1992 Corrado SLC
    Baltimore
    Yeah I didn't pay attention to how fast I was going, but I hit one of those parking stops. I'm surprised the bead held on the drive home.
    May 08 2012
    2006 Suzuki SV650
    Atlanta, GA
    Quote Originally Posted by Almost1 View Post
    That held air?!?
    '11 S-Line A4 Avant
    '98.5 A4 2.8Q sedan retired after 14 years of service
    Oct 02 2013
    1992 Corrado SLC
    Baltimore
    ^ I know right? It still has pressure almost 24 hours later
    Dec 10 2011
    991 C2S, Stage 3 S4, E46 M3
    CLT | MKE
    Wow! Super surprised that held air. Not too bad a mistake if that's the only damage!
    How did you hit the parking curb? Slid directly sideways into it, or did you just knick it? Speed? Was it secured to the ground or did it move when you hit it? I ask because if you slide sideways into a curb, it's really easy to throw off the alignment or damage the wheel bearing.
    -Hayden
    B9 Q5 | Brilliant Black
    E46 M3 Cab | Steel Grey
    Oct 02 2013
    1992 Corrado SLC
    Baltimore
    Quote Originally Posted by LINDW4LL View Post
    I slid sideways into it. The stop was covered in snow, but I think it was anchored. If i had to guess id say I was doing 20mph or so.
    Oct 22 2012
    Markham
    Quote Originally Posted by ryanhmusic View Post
    that would be lucky.
    did something similar a few years back in the snow and my rear rim looked the same. had to replace rear subframe amongst other things (had to tilt steering wheel 30 degrees just to go straight), $2k in damage.
    Senior Member Two Rings Nightkiller6's Avatar
    May 30 2015
    San Diego, California
    Alignment is definetly off after something like this.
    I would guess you need:
    -new wheel
    -alignment
    -possible suspension damage?
    B8.5 Ice Silver A4
    Mod List- USP Motorsports Full Interior Lighting Kit | USP Motorsports RFB Led Reverse Lights | Hoen Xenonmatch Fog Lights | iJDMtoy Led Front Turn Signals | USP Motorsports Honeycomb Grille | Hartmann HTT-256 MA-M 19x8.5 ET 38 | Michelin Pilot Supersport 255/35/19 |
    Nightkiller6 is my Xbox gamer tag I made when I was 8.
    Oct 02 2013
    1992 Corrado SLC
    Baltimore
    Well I got out there and jacked up the car. There was no noticeable subframe damage and the wheel bearing had no play. I drove it in my parking garage and I could only get it up to 30, but there was no noticeable variation in the alignment, odd noises, or vibrations. Ill probably get an alignment anyway after I replace the wheel just to be sure.
    Apr 19 2014
    Long Island
    Sorry to see that. Glad it isn't too bad. Were those all seasons?
    Veteran Member Four Rings ENVē's Avatar
    Nov 04 2010
    Happens sometimes man. I only play in open parking lots that dont have those stops.
    500AWHP/500AWTQ
    @Driven_Not_Hidden
    Veteran Member Three Rings PBKIDD24's Avatar
    Apr 30 2015
    Spun out on a patch of ice in my old car and slid sideways into a curb. Messed up my wheel, bearing and alignment.
    2015 S4 P+ Daytona Grey Pearl Effect
    APR / Milltek / Bilstein / Eibach / 034Motorsports
    Build Thread • Instagram • Flickr
    Past Cars: 2015 A4 Build Thread
    Oct 02 2013
    1992 Corrado SLC
    Baltimore
    Quote Originally Posted by homelessNY_LI View Post
    Those Continentals are all seasons!
    Quote Originally Posted by ENVē View Post
    The stops were on the perimeter of the lot. I just couldn't pull away from them
    Nov 04 2010
    All seasons suck
    Sent from my SAMSUNG-SM-G920A using Tapatalk
    500AWHP/500AWTQ
    @Driven_Not_Hidden
    Senior Member Three Rings B7AudiSline's Avatar
    Jul 14 2012
    Eastern Shore,MD
    Wow.............I can't believe that has held air
    2012 B8 Quattro Prestige S-line/Black Optic PKG/Phantom Black Pearl/VCDS/TINTS/APR HFC W/3inch downpipe/Kohlefaser Luft-Technik Intake System/Turbo inlet hose/APR Stg 2/R8 Coil Packs/
    Luft-Technik Intercooler w/hard pipes
    RIP 2007 BB A4 2.0T Quattro Tip S-line Titanium Pgk/APR STG 2/Test Pipe/3'' Downpipe/Forge DV/K&N Drop in Filter/VAGCOM/APR Snub Mount/ECS Vent Pod Boost Gauge/CC/HOEN Fogs/LED City Lights/ECS LED Plate Lights/Tint/RIP
