Results 1 to 15 of 15
    Jul 17 2015
    Uk
    Resonance at 1000rpm
    Just noticed a resonance (exhaust maybe) as the engine goes through 1000rpm.
    Is this normal? never noticed it before though
    Veteran Member Four Rings MrFunk's Avatar
    Apr 04 2012
    MSP
    Aftermarket exhaust?
    Jul 17 2015
    Uk
    nope, stock. passenger side was replaced 8 months ago though after a motorbike hit me and knocked it off
    Veteran Member Four Rings Brother Owl's Avatar
    Mar 24 2015
    Denver
    My stock exhaust can be a little bit "boomy" at ~1000rpm when backing out of parking or reving to get car moving. 6MT
    B8.5 S4 Estoril Blue Crystal 6MT : IE DP 3.2PR
    Denver to Vegas in 9:26
    Dec 29 2015
    Mine is the same. Neutral rev to 1500rmp and let the needle drop it gets rough right at 1000rpm
    Think it's normal
    Veteran Member Three Rings shoe3k's Avatar
    May 18 2015
    weedwhacker
    No where
    I have encountered the same resonance and seems normal.
    Previous: |'18 Golf R | '17 S6 | '15 S4 | '15 STI | '12 GLI Autobahn | '08 Passat | '04 R32 | '05 GTI 1.8t |
    Veteran Member Four Rings jygesq's Avatar
    Aug 22 2014
    1986 Honda CH 150 D scooter bought new
    bloomfield,ct
    Most engines have a resonance point
    2015 S4, P+, Florett Silver,black /silver nappa leather, S-tronic ,sport diff,B&O ,tech package ,supercharged badges. All season tires ,cargo net, factory dip stick
    Apr 04 2012
    MSP
    The downpipes have been known to have some resonance. It's more noticeable with aftermarket exhaust in cold weather (IMO). I don't even notice it any longer but the first winter after putting my AWE on I noticed it at around 1200 rpm.
    Jul 17 2015
    Uk
    Cheers guys, weather has been a bit up and down here (UK) so close tolerances and that are likely to be the reason. Will ask my local tech to ramp it and give it a prod if it doesn't clear by itself
    May 24 2012
    Elkridge, MD
    just had my downpipes replaced due to vibration around 1100rpm. tech said he could see the downpipes vibrate when under the car... fixed the issue
    2013 Estoril Blue DSG SportDiff AK VMR713
    Jul 17 2015
    Uk
    My tech thinks the cats are loose. Seems odd but I do trust him.
    We know how much they cost....
    Does it seem the likely problem?
    Aug 28 2014
    I think I had the same issue. If I went through or held the RPMs around 1200, then there would be a bad vibration (much more so when cold out). Ended up having to replace both downpipes. It took a while to get the dealer to fix under warranty, but after they were replaced there was no more vibration. Not sure exactly how they failed, as there was no exhaust leak, but they were ultimately the issue for me.
    2014 S4 - Moonlight Blue
    Jul 26 2014
    Had the vibration issue @1000 rpm from day one of owning the car, fixed by replacing the flex pipes on both downpipes.
    2011 S5 Sportback
    Jul 17 2015
    Uk
    Have attached a video guys to see if the noise was the same.
    Downpipes sound a bit better than 2 new cats
    https://youtu.be/ig4E9TTQVlk
    Jul 17 2015
    Uk
    gave it a few more beans and there's a bit of a clonk around 3000rpm then the tweety bird sound at 1100rpm
    didn't know the car wouldn't let you rev over 4000 in P or N until I tried it
    https://www.youtube.com/watch?v=TjJCwPiqqxE
