Results 1 to 17 of 17
    Apr 15 2014
    Ottawa/Gatineau Canada
    I amy be going for a long drive to pick up some B6S4 Recaros.
    Any special tools I will need other than a 8 or 10 mm tripple square?
    Are all the B6 S4 seats manual? so will I be able to move the seat around without a battery in the car (donor) and also position them to fit in the back of my Avant with the seats down.
    May be getting front and rear seats if the Donor car is an avant
    Thanks all.
    P.S... Anyone got pics of "white" B6 S4 seats in a B6 A4 that came with "black" interior?
    EDIT... got a pic to answer the P.S. question...
    http://fourtitude.com/gallery/genera...scaled_600.jpg
    2004 A4 Avant Quattro. (H&R springs, S100 Nav unit, Neuspeed Cat back, Torque solutions Snub mount, Thor Skid Plate, APR Stage 1, 18" S4 Rims, 2X Podi / Oil Press / Oil Temp / Boost/VAC, Full LED interior, Backup Camera/Screen, Upgraded 2.0 Coil Packs, Vag-Com, B7 Center console/B7 Hand Brake, B7 Aero wiper arms B7 rear headreasts,APR Carbonio intake, Fan washer sprayers,
    2014 VW Tiguan. (bone stock)
    Nov 10 2015
    Sudbury, ON
    Quote Originally Posted by Luxus Panzer View Post
    Thanks all.
    god thats pretty
    2004 Audi A4Q 1.8T Ultrasport 6MT
    Frankenturbo'd, Meth, front mount, custom tune, full exhaust, bunch of other crap
    2004 Audi A4 Quattro 1.8T Tip Sport Pkg SOLD
    18" S4 Avus wheels l Eibach Lowering springs l Magnaflow 16601 l 3" TP l Pioneer Double Din l USP Bumper/S4 Door blades/Spoiler l Black on Black
    Veteran Member Four Rings AvantNoir's Avatar
    May 22 2007
    Santa Monica CA
    Nice find. WAY BETTER than the stock B7 seats you were thinking about.
    S4 seats are power. Most likely, you'll need a battery to move them.
    2005 USP A4 Avant 1.8T Follow me on instagram @m27autowerks
    Jul 03 2010
    1988 Merkur XR4Ti, 1986 911 Coupe, 1991 Alfa Romeo 164
    New York
    Quote Originally Posted by AvantNoir View Post
    Agreed. If you have some 14.4V cordless batteries, they work just fine for this purpose. Even ~18V should be okay.
    When I got my S4 seats I removed my passenger seat before leaving home and just plunked the new one in it's place. It all worked fine except for setting an airbag code. I just cleared it later with no ill effects.
    Brad 2002 Quattro 1.8T w/ 2.8 B5 5-speed
    Feb 12 2008
    Michigan
    Get the back seats too!!! Sedan seats will work in the avant, you want them to match
    Apr 15 2014
    Ok, thanks all.
    So any other special tools?
    Veteran Member Three Rings lyates1987's Avatar
    Sep 17 2014
    Lakeway
    Just a T30 torx for the rear back seats if it's the same as stock
    May 22 2007
    Santa Monica CA
    Quote Originally Posted by lyates1987 View Post
    It's actually a triple square drive, not a torx. Torx will run the risk of damaging the bolt head.
    May 22 2007
    Santa Monica CA
    You want to get an M10 triple square drive bit
    May 22 2007
    Santa Monica CA
    To clarify, the front seats, you'll need the M10 triple square. The back seats, a torx is fine.
    Veteran Member Four Rings eljay's Avatar
    Aug 13 2015
    NS
    You'll have no trouble fitting the whole set of seats (both front seats, plus the rear bench and backs) into your Avant with just your rear seats folded down.
    Avants can swallow an amazing amount of stuff!
    Those will look fantastic!
    Current: 2016 Audi A4 Allroad (in progress)
    Past: 2005 Audi A4 1.8T Quattro Avant / 6-speed / Ultrasport - SOLD
    Apr 15 2014
    Had everything set up and ready to drive 2 house to pick up.
    Frenchie sold them out from under me.
    $$ rules I guess.
    Feb 27 2011
    Winnipeg
    $$ rules I guess.
    Drive to Winnipeg, I've got a set of white avant recaros for sale
    Established Member Two Rings OttawaWill's Avatar
    Mar 02 2015
    Ugly, Boring, Family mover.
    Brutal.... I would have loved to see them. Cash in hand is a powerful persuasion. We're you getting ready for the road trip when you found the water pump and washer leak?
    Apr 15 2014
    Quote Originally Posted by OttawaWill View Post
    I was fixing the washer pump while I waited for him to get back to me.
    May 22 2007
    Santa Monica CA
    $$ rules I guess.
    WHAT!?!?! That sucks. I'm always amazed when this sort of thing happens. Frenchie should have at least let you know there was another buyer.
    May 22 2007
    Santa Monica CA
    This just popped up on my radar - B8 A4 Sport Seats in Sacramento, CA:
    http://losangeles.craigslist.org/sfv...410240946.html
