Results 1 to 10 of 10
    Veteran Member Four Rings Gunnark100's Avatar
    Oct 21 2012
    Earth...
    Reminder - Correct electronic oil level check at present moment on DIS!
    Big thank to Stevee from Russia,
    Found something interesting from Russian forum, have not seen this before. Should be correct electronic procedure to measure actual oil level at present moment. Just translate page with google toolbar or similar and test. People who dont have oil temp, just make a bit longer drive, as reported it will not measure if engine(oil) is not properly warm. Should work on all B8+B8,5 with electronic oil level gauge and who have reset button on the right lever!
    https://www.drive2.ru/l/6257833/
    1.After drive, stop and shut off the car on even ground
    2. After 3-5 minutes pull the bonnet release and open drivers door
    3.Switch ignation on(dont touch pedals or start the car)
    4.Press reset button on the right lever twice etc and oil level should appear in DIS.
    Enjoy testing:)
    Retrofits: FL taillights / MMI 3G & 3G+(Street view incl.)/ Color Cluster & FL S5 Cluster/ BiXenon/ ADS Lite
    Other: ECU Tune/ VCDS Tweaks/ FL Gearknob/ Soundproofing/ Interior 6D Carbon Wrap/ Rieger Rep Front Bumper Valance/ Basic sound(8) upgrade to "ASS"(9+1) + B/O Sub(in sidepanel)/Tweeters + Activsub/ Efficiency Prog via Cluster & Gateway flash/ Sideskirts/ Window Tint/ Wsp Peeler reps/ License plate & Interior leds
    Veteran Member Four Rings bluetori's Avatar
    Jan 14 2010
    Discovery 4, RR7, SP Fireblade
    Georgia
    Thanks for reminding how to do this again I have been driving myself mad trying to remember how to do this, and always look forward to your posts. ;)
    Feb 15 2016
    Cambridge,Ontario
    What am i missing . Just look on the mmi
    2014 A4 2.0TQ Technik Manual
    2006 A4 2.0TQ Manual
    1978 Porsche 911SC Targa
    1976 Yamaha XS 360
    Feb 24 2004
    Minneapolis
    I'm a little like you. If I just had the hood open, I get in the car, turn on the ignition without starting the car, go to the MMI and wait about a minute.
    11 A4 Q, Prestige, Black
    207,000 miles, APR Stage 1
    Feb 15 2016
    Cambridge,Ontario
    I'm not even sure why people are popping hoods and opening doors.
    I just get home from a drive wait 2 minutes and check mmi. I'm obviously missing something about this thread
    Sent from my SM-G973W using Audizine mobile app
    1976 Yamaha XS 360
    Veteran Member Four Rings adamazing's Avatar
    Apr 26 2014
    San Diego, CA
    Same boat. I'm not sure what all the extra steps mentioned above do, other than create more work.
    2013 A4 Quattro Green Black Iridescent / APR E85 Stage 2 / AG F421 Polished Copper / Eurocode FMIC + HFC / AWE Quad + CF Diffuser
    build / instagram / flickr
    Nov 26 2018
    If you've just popped the hood you'll get no reading on the MMI. I'm guessing that'd be why.
    2013 B8.5 A4 Quattro 6MT | 034Motorsports HFC | IE Stage 2 Tune
    Sep 18 2018
    Calgary
    I am guessing the reset button erase old value and force start a new reading.
    Jul 16 2018
    Atlanta
    If the car is saying the message rather than displaying an oil level, all you do is make sure the engine is warm (ie, go drive it) and then turn the car off (press start/stop twice or open a door to get complete power off). Then turn the power (but not the engine) back on and go to the oil level display in MMI and wait till it shows a level. There's no need to do any "reset". I don't know if this will give you an oil level bar if the engine is cold; I don't know if these "reset" procedures will give you an oil level bar if the engine is cold.
    2009 A4 Avant 2.0T quattro Prestige, 270k miles
    Oct 19 2018
    KCMO
    If the hood is open, the oil level will display in the DIS.
    It may be to save a tech a few seconds during an oil change, or in case the car doesn't have MMI.
