Results 1 to 19 of 19
    Established Member Two Rings Danny2323's Avatar
    Mar 30 2015
    Cincinnati
    Ultra Racing Chassis Braces?
    I just received the CR-15, but haven't installed it yet. Other than the CR-15 and the AK, what else is available? I searched and found the Ultra Racing bars (I have zero affiliation with them).
    Has anyone tried these out? Any good results? I searched, but it didn't appear there's been anyone that's tried them (only two threads mentioned them).
    Veteran Member Four Rings blbroo's Avatar
    Oct 26 2012
    SQ5, Nissan D21, 435i Gone: K04'd B8 A4, M235i, UrS6, B9 SQ5, D21 Nissan 4X4
    St. Louis, MO
    I have the rear lower brace and the strut bar (a4 only) and both pieces are really well made. Doubt the rear brace does anything as it bolts to a solid piece that is already linked, to itself, on both mount points. The strut bar adds more of the same as the CR15.
    Signature overridden by community admin.
    Collector of German things.
    “Whoever said laughter is the best medicine had clearly never tasted scotch.”
    Veteran Member Four Rings Over9000's Avatar
    Oct 14 2013
    ¯\_(ツ)_/¯
    I had the mid brace on my S4. It made an enormous difference in chassis rigidity. Definitely recommend.
    Doug (a.k.a. Dung from No Lube, No Problem)
    '21 TTiesRS TeamOEM
    Nov 28 2015
    Montreal, QC
    found the thread in A4 section, you should read it.. I'm curious about clearance issue since they are made for A4 not S4. maybe with aftermatket exhaust it could not fit and then i read that ultra racing make these strut over RHD frame and not LHD so theres not more complexity.
    I would love to run them. much less expensive than AK or 034
    Sep 24 2014
    2015 Audi Q3 Quattro, 2017 Corvette M7 Grand Sport, 2017 Audi SQ5, 2019 Porsche Macan, 24 Jetta GLI
    Central NJ
    Where does the midbrace attach to?
    May 17 2012
    Houston, TX
    Anyone have pics of these? I'll prob try these out in he spring.
    Mar 30 2015
    Cincinnati
    Quote Originally Posted by AKPS4 View Post
    I'm looking for pics too. I'm concerned about exhaust and speed bump clearance for the mid lower brace (sits under exhaust), and clearance over the supercharger for the strut tower brace. The only pic I could find was the strut clearance over an A4 engine cover, but I don't know how tall those are compared to the S4's supercharger. Here's all I found:
    Post #34: http://www.audizine.com/forum/showth...t=Ultra+Racing
    Post #5 and #39: http://www.audizine.com/forum/showth...t=Ultra+Racing
    Strut Tower on a B7: http://www.audizine.com/forum/showth...duct-installed
    Post #7 - Mid on a B7: http://www.audizine.com/forum/showth...t=Ultra+Racing
    Oct 26 2012
    St. Louis, MO
    If there is anyone in the St Louis area with an S4 that wants to test fit the strut bar, I'd be willing to pull it off. It's just four nuts, pretty quick to remove and install.
    I can also try to get blackjack to swing by.
    Sep 24 2014
    Central NJ
    I had an UltraRacing chassis bar for my VW CC. Looks well made, considering the price, certainly no better or worse than most of the other brands. Other than lighten you wallet, and make the car a little heavier, it can only help chassis rigidity.
    Jan 01 2012
    Seoul, Korea
    I had the middle brace for about 2 years.
    Huge difference.
    Surprising the rear rigidity gone up significantly...easily feel the difference when going into basement parking lot turns...
    One side note is that because of the protruding prongs, sometimes the brace will touch/scratch grounds, so becareful.
    Mar 30 2015
    Cincinnati
    Quote Originally Posted by hjl113 View Post
    Huge difference.
    Was this on a B8 S4? Got any pictures of it mounted?
    Established Member Two Rings WeeKenny's Avatar
    Jan 05 2015
    Scotland
    Anyone tested the 2.0 A4 front upper brace on the S4?
    Nov 28 2015
    Montreal, QC
    I think the best thing would be to post in the A4 section then someone local with a s4 try to fit it.
    However, I think it suck we have to go throught this instead of ultra-racing simply taking a S4 B8 and try their part see if it fit or not, but then again, it appears that Ur are working with RHD car which appears to have different mounting point + there's slight difference with B8 vs B8.5 so at this point it seems like a gamble..
    Oct 26 2012
    St. Louis, MO
    I know of myself, Lettuce (Boston) and Slowone11 (near Boulder) with the UR strut brace.
    There are also a few US distributors that might be able to help with a test fit. DNA in Rowland Heights, CA and CDM in Dallas, for two.
    Stay classy.
    Jan 05 2015
    Scotland
    Worst thing is if you go on ultraracing.my it lists the B8 S4 upper brace with part number, then ultraracing.uk claims they can't source me the part.
    Oct 26 2012
    St. Louis, MO
    Quote Originally Posted by WeeKenny View Post
    I saw a pic once on their site listed as S4, but the car shown was a 2.0t
    Stay classy.
    Jan 14 2009
    2014 S4 2014 GLK Diesel. 06 Jetta TDI
    pasadena md
    how much is that Mid brace?
    Sep 24 2014
    Central NJ
    I bought the UltraRacing upper bar (UR-TW2-2762) on Ebay, shipped from Malaysia, it arrived bent....new one on the way. I will let you know if it fits my 2010 S4. It looks very similar to the bar they sell for the A4 2.0T (UR-TW2-1412), but with different shaped end-brackets to clear the 3.0 V6.
    Jan 14 2009
    pasadena md
    Quote Originally Posted by S4'ed View Post
    Bent?? I wonder if it will help if it bent in transit. Hopefully it was just bent when it was assembled. Let us know how you like it and install and if it rubs on anything
