People aren't trying to be rude. They and I are really trying to help you. For those who have been through it, it can be a tricky game. For your power goals, people are basically suggesting what is tried and proven over and over again. 3.5Krpm full spool is what you want, and the eliminator can get you that. 275whp? Eliminator can get you that too. But when it comes down to it, your main focus should be reliability. And the eliminator handles that dept rather well. And when or if you do decide to build your motor and step to a bigger turbo, simply sell it and then upgrade. And if you don't, then you have a tried and proven 300whp reliable setup that spools at roughly 3.5K rpm...exactly what you are looking for.
If you go the eliminator route, you will do a bunch of upgraded supporting mods. So when you want to go bigger, they should be already finished. And as mentioned above, things change all the time. Better turbochargers, faster spooling ones, better designed manifolds, etc. It's a technology that keeps on growing. And I'm sure you know journal bearing turbochargers spool slower than ball bearing. So if you decide on a T3 entry level journal bearing turbo, it's not to say that it would perform better than the eliminator. Because it won't. T25 for stock block is the way to go. This is one reason the eliminator shines on the stock block. Stock port is small, but it keeps up velocity. T3 is more for the person chasing more power through a wider powerband. And V band is just the most versatile flange (can be used on a lot of apps).
With that being said, I'm still all for people going their own route. I suggest a T25 Treadstone manifold with an EFR T25 .64 A/R IWG 6258 and get a competent tune that won't blow your engine. Only thing that I can see having faster spool with both matching and higher power goals than the eliminator as far as these types of setups go (single turbo). Pricey turbo, but it's what I believe to be the ultimate stock block setup (pretty sure a person in my section runs this setup, but doesn't post. but he also placed in forged rods to be safe). But if you want to simply tinker and play with your car, I'm all for this too
. Go for it. But I still suggest T25 for the stock block.
