    Feb 23 2004
    2004 A4 1.8T Ultrasport 6MQ
    Stow, OH
    In need of driveshaft info/options
    Had a great time traveling to Detroit to go see that big car show. The drive to the show was uneventful. So was the drive home. Car sat at home for a day as I worked from home. Today, I drove to work and was getting a big rattling noise with the car cold and in gear. Noise would go away if the clutch was pressed in and was less evident in gears 4-6.
    Stopped at the local shop to have things checked out. Turned out my front left and rear right axles were shot and making the noise I was hearing. Have new axles on order to get replaced next week.
    While they were doing inspections, they're seeing the driveshaft has about 4 months of life left and needs replaced. It's the original driveshaft with 316,000 miles on it. I think it has done well.
    I'm trying to get info on what options I have for a replacement. I have a 2004 A4 6 speed with quattro. It's one of the early Ultrasport models built (built 9/11/2003). Am I limited to just B6 A4 6 speed driveshafts?
    Seems new ones can be anywhere from $500 up to $1500+ (for new OEM). Have seen a used one listed on eBay for $160, but not sure if it's the right one. Don't know what the right part number is.
    What options do I have?
    USP CLUB MEMBER #34
    Veteran Member Three Rings B6ayfour's Avatar
    Jun 21 2015
    2014 S4 6MT, 1989 535i5, 1988 ASC Mclaren Mustang 5-speed
    LI, NY
    more about what the noise sounded like, im getting similar issues. weird noise coming from the rear end goes away when clutch is depressed and only seems to happen in 2nd and 3rd
    Feb 23 2004
    Stow, OH
    Quote Originally Posted by B6ayfour View Post
    The axles were making the noise for me. When in gear, the torque would put stress on the axles and get a ratchet sound.
    USP CLUB MEMBER #34
    Veteran Member Three Rings 19jdog's Avatar
    Jul 28 2014
    2006 Mini Cooper s - 2013 Mini Cooper S - 2007 C6 Avant - 2006 GSXR 750
    SACRAMENTO
    I bought a drive shaft from these guys 5000 +- miles ago when I did my 6 speed swap.
    clicky
    11 Q7 Prestige TDI S Line - Stance SF 03 20x10
    04 B6 A4 USP 2.7t
    USP CLUB MEMBER #198
    BEL 2.7t SWAP- Rohana RC7 19x9.5 33mm - 034 REAR SWAYBAR - TIP TO 6 SPEED SWAP
    Mar 28 2015
    1987 Dodge Raider G54B Turbo
    Portland OR, United States
    8E0 521 101D (superseded to 8E0 521 101T) drive shaft ( from a 2005 B6 auto).
    http://www.audizine.com/forum/showth...9#post11342449
    What I learned doing my swap.... The drive shaft from an 2005 auto has the same pn as the 6 speed manual tranny for your 02X tranny. I picked one up on Craigslist with 105,000 miles for $80, good price but should be possible for you get something good for under $150.
    Try Car-part.com for good used units.
    http://www.car-part.com/cgi-bin/sear...ey=&userPage=2
