Results 1 to 6 of 6
    Senior Member Two Rings djshaunmichael's Avatar
    Mar 13 2013
    Boston
    Oil level question.
    Oil level on mmi indicates it is empty, but there is no low oil light on? Add oil or no?
    Mar 21 2015
    Get a dipstick. Light comes on when 1 quart low.
    Oct 14 2012
    Empty...for now...
    SE PA
    Quote Originally Posted by djshaunmichael View Post
    I noticed this on my B8 a couple years ago. It took a few more miles of driving after I noticed the low level on the MMI readout before the low oil level alarm went off in the DIS. Best bet is to add some oil now. It should take about a quart to top it off from where it is now. Once I noticed that the B8 was drinking some oil I kept a quart in the trunk at all times in case it got too low while I was out on the road. I would also recommend buying an OEM dip stick so that you can get manual (accurate) readings going forward.
    SOLD 2015 Daytona Gray S4
    Veteran Member Four Rings Dr GP's Avatar
    Jun 08 2005
    Lexus RX 350
    SE, PA
    I believe the MMI actually indicates you are 1 qt low. NOT EMPTY. If it were empty, your engine would be fried by now. At some point soon, you will get a warning advising you to add a qt of oil(if it is in fact low). Some have had issues where the MMi or warning indicators were not accurate. In my experience, I have learned not to trust the oil level obtained from the MMI. But the warning to add 1 qt has been accurate. I know this because I have a dipstick to compare the 2 readings. I trust the dipstick. BTW, today added the qt I also keep in the trunk
    Veteran Member Four Rings vwblackb5's Avatar
    Jun 26 2007
    New Jersey
    As a B5 owner, I've learned to never wait/trust for the oil light to come on. I usually always check the dip-stick level. Typically if the light goes off (on a B5) low oil could quickly escalate to a clogged oil pick up screen or something else catastrophic.
    TL;DR - I don't trust MMI oil level on the S4, bought a dip-stick for the B8.5 to provide proof positive (chalk it up as lesson learned from B5 ownership).
    16 B8.5: S4 | Premium Plus | Ibis White | PNY | PPS | GH2 | 1BL | Black Nappa | CTS
    99.5 B5: K04-015 / GIAC PC-16 / 315cc Genesis / Custom FMIC / 034 TP / TT Downpipe / Jetex Catback / Forge 007P / ECS AFPR @ 2.7Bar / ABD Tuning Intake / Blinktek Heatshield / Koni FSD / Eibach Pro Kit / SouthBend Stage 2 Endurance OFE HD / 312mm Slotted A8 BBK
    Mar 21 2015
    Ecs has a nice billet dipstick too
