Results 1 to 2 of 2
    Apr 10 2012
    2003 Audi A4 1.8T Quattro
    Fort Worth,TX
    Is my ABS module shot? VCDS error inside
    I am fighting with an apparent ABS issue. I get the dreaded ABS/ESP light. I replaced the brake switch, and the G201 brake pressure sensor. Now I am getting
    01435 Brake Pressure Sensor 1 (G201)
    48-00 Supply Voltage
    The only other thing I can think of is its the ABS control module?
    2003 A4 1.8T Quattro Auto, Custom Stage1 tune, N70, 550cc Fuel Injectors, B7 console (with cup holders!)
    Senior Member Three Rings crazyquik22023's Avatar
    Jan 30 2012
    Brunswick, Ohio
    Try doing a basic settings adaptation for the pressure sensor. If that doesn't work you probably will have to get a different ABS module or have yours rebuilt, G201 is internal in the ABS module. You can get the module rebuilt at a place such as module masters or you can get a new/used one.
