All,
So as my car gets up there in miles I've noticed that my transmission shift quality has gone downhill very quickly. Was always clunky in traffic...well before it was tuned. Since about 70k miles onward it got pretty bad. upshifts remind me of the 3 speed auto in my 1992 Saab 900 and downshifts when coming to a stop are abrupt and causing the rpm to jump up....the car feels like its lurching forward as I brake. Also the engagement/ disengagement of the transmission in traffic creates quite the thunk sensation. I'm replacing my engine mounts next weekend with new 034 ones since it can't hurt. Already have the tranny and differential inserts.
When I spoke to multiple dealers they've always told me that the transmission is a non serviceable item.... like a solo cup. They said that I should never replace the ATF fluid or filter...ever.. and that doing so will cause the transmission harm. They even said they've never done it before so they wouldn't even know how. As with most "lifetime" parts on Audis, I called bullshit. Much like the fuel filter...absolutely not a lifetime part. If it's doing its job....it's going to clog up over time. What's odd is that I didn't find much from BMW or MOPAR (both users of the tranny....saying its a non serviceable item.
After much research and hearing conflicting things, I finally emailed ZF and even called them. Much to my lack of surprise, I was right. Over the phone I was told it's "ridiculous" that they say it will last the life of the car. The rep said it's fluid...of course it needs to be changed... nothing lasts forever. Over the phone they said it's highly recommended to do a full flush and filter swap between 60,000-90,000 miles. In the email I received back they said every 60,000 miles or 8 years...whatever comes first. So right now as I sit here with a transmission that feels like it's not long for the world....I'm pretty pissed off at Audi and the dealer. My car is all highway cruising miles...92,000 of them and is only 3 years old. This transmission should not be acting like this. It also has a torque capacity of 480 lb/ft....so my 343 lb/ft from my tune on 93 octane doesn't even come close.
I called the dealership and asked them to get back to me on why they told me not to ever change it when the manufacture of the transmission told me its ridiculous not to.... they said they'll get back to me shortly. I've also emailed AoA asking for a better explanation since there's a chance I've damaged my transmission due to the instructions given to me on multiple occasions by Audi.
I've asked ZF to give me the part numbers/ exact Lifeguard fluid types needed for such a service. I will post them when I receive the information. Below is also the email from ZF:
The OE's always follow the lifetime fluid rule. Especially if the transmission is still under warranty. When it is under warranty we follow the same rules because you can void your warranty by changing the fluid.
When the transmission is out of its warranty period most people like to use the maintenance schedule of 60k miles or 8 years. A drain and fill with a filter replacement is strongly recommended. We strongly suggest using the OE or ZF Lifeguard Fluid 8 fluids. Other types of fluid may cause shift issues.
In your situation, I suggest you check the fluid level and quality of it. There are times when the transmission leaks and a low fluid condition can cause shift quality issues. Once you determine the fluid is ok or not you will have a better idea of why the transmission is acting up. If everything is good then I would try a fluid change and a software update. If the fluid level is low let me know and we can go over your options.
If i'm missing something here let me know haha
