Results 1 to 3 of 3
    Oct 19 2015
    WI
    Accelerator pedal to the floor and VAG COM says 90% - Is that normal?
    I'm just learning about what I can and cannot do with VCDS, so I may be worrying about nothing here, but I thought I'd ask.
    Last night with the ignition on, but the car not running I was looking at some of the data I could view with VCDS and noticed I could see the Accelerator Position by percentage. I noticed that even with stomping on the pedal (again, car not running, just sitting in the garage) it barely got to 90%. Here is what I got:
    Not touching the pedal: 15%
    Pedal pressed until contacting kick-down switch: 76%
    Pedal fully depressed: 90%
    Again, this could be completely normal, or perhaps there's another value I should be looking at, but my expectation was that a fully depressed accelerator would return a result of 90%. It also surprised me that without engaging the kick-down switch I was only at 76%.
    Any thoughts on this?
    Veteran Member Four Rings HyperM3's Avatar
    Mar 20 2004
    Lawrenceville, NJ
    21 S5 Coupe - RacingLine strut brace/034RearSwayBar/CTSTransMount/034 tune/VPS Res Delete/CTSIntake
    10 S4 (gone),13 S6 (gone),14 S6 (gone),14 S6 (gone),16 S6 (gone),17 A4 (gone),19 S4 (gone)
    20 BMW R1250RS
    ACNA Lifetime Member - 26690
    Respond to a post with an answer, they will keep asking questions. Teach them how to RTFM, they will learn to help others.
    Oct 19 2015
    WI
    Quote Originally Posted by HyperM3 View Post
    Thanks Hyper. I tried the TBA last night with VAG COM and it wouldn't allow it. I'll try this method tonight and recheck the values.
    I also found some other threads that discount the importance of the percentage actually reaching 100%. In a nutshell the logic was that the ECU can interpret that percentage and adjust it to mean 100% to the ECU based on some tolerances that are built in.
    Thanks again.
