Results 1 to 12 of 12
Thread: Clunking Debug
    Feb 13 2004
    AW E30 M3 & PB B7 RS4 (DD)
    Clunking Debug
    Pardon me but this car is the most clunking Audi I ever had (A4 B5 & A4 B6 Avant). How do you debug the clunking? I see little seeping on the strut when I replaced my starter last weekend. The upper control arms look new (no dust). They look solid to me.
    Jun 25 2009
    07 RS4, 91 BMW 318is
    SC
    When is it clunking? Check mounts and struts. DRC may be on the way out or you may have a blown mount somewhere on the drivetrain.
    Feb 13 2004
    Whenever go over bump or pot holes (thank god not that many in my county), not turning. I notice the front sway, even after tighten seem to be loose, so I added a washer to ensure it is tight, but still clunk :(
    Jun 25 2009
    SC
    You said one of the struts is leaking? There's your answer. Replace it or go coilovers.
    Feb 13 2004
    There are trace of very little leaking, but it is not wet. Oh well Koni time, too old for coilover :)
    Oct 11 2007
    Suburbia
    Your DRC is clunking, it means it may be on it's way out. Do you know if the recall was done previously? Mileage?
    12' R8 Daytona/CF V10 6MT
    ~VF750 supercharged~Avior Ti non-res~GT coilovers~Girodiscs~Wingbacks~CF S-wheel~Maxton Aero bits~
    07' RS4 Daytona/Panda
    ~Jackal tune~Zinram 70mm DPs~JHM res catback~Custom CAI~Bilstein PSS9s~Girodiscs~JHM shifter~
    Junior Member Two Rings
    Nov 01 2013
    Quote Originally Posted by WinterRunner View Post
    Doesnt the upper control arms clunk over a speed bump if they are on the way out? Now he says his struts are leaking so his sounds like drc.
    Feb 13 2004
    Don't know if DRC has recalled yet. I bought the car from original owner but he did not provide me any paper work.
    161K :(
    Veteran Member Four Rings ryanhmusic's Avatar
    Aug 05 2014
    jack stands, a power washer, hand tools, bones of my fallen enemies, etc
    Quote Originally Posted by d2a4 View Post
    161K :(
    at 161k its probably time for new suspension, control arms, tie rods, and associated rubber pieces...
    I'm living for the day I can park something Italian inside of my house.
    I had one wild summer on match.com. -some jackass
    01100010 01100001 01101110 01100001 01101110 01100001 00001010
    Oct 11 2007
    Suburbia
    ^ I would say so
    Veteran Member Four Rings singleframe's Avatar
    Apr 25 2010
    2007 Phantom Black RS4, VW eGolf
    Venice Beach baby!!! 🌞
    Quote Originally Posted by ryanhmusic View Post
    This!
    IG @myRS4 | 2007 RS4 | Phantom Black | Milltek'ed | KW H.A.S. kitted | Rotiformed (SPF DDT 19X10 +25) | PSSed 275/30/19 | LED DRL'ed | H&R wheel spaced | 034 Density Line control armed | Hotchkis F + R Sway Barred | Apikol rear-diff mounted | K&N Filtered | Ziza lit | Passport 9500ix hardwired | Dension Pro BT'ed | StopTech Brake Padded | window trim matte black vinyl wrapped
    Veteran Member Four Rings your daddy's Avatar
    May 29 2007
    NOW-17 R8 V10+,08 RS4/Ti/AE,2021 S6, THEN-08 ibis TI,02 337, 01 S4, 92 gti vr6,90 corrado, +many
    Billerica/Lexington,MA
    if the DRC is leaking, theres your answer. ditch it and go PSS9. never look back.
    Rick autoengineering.com @autoengineeringlexington
    -APR-Integrated Engineering-JH Motorsports-034 Motorsport-ECS tuning-Forgeline-CTS, plus many more
