Results 1 to 8 of 8
    Jan 22 2016
    Audi TT and Touareg
    Orlando, FL
    Anyone in Orlando with a vag that can help a brother out? :)
    So I am new to the S4 world coming from an Audi TT and Touareg... I just took a gander at ALL of the different vag things we can do with this car! I am not comfortable doing these things my self and I don't mind throwing a few dollars or a case of beer to someone that can give my car a jumpstart on some of these vag things I have found... Anyone in Orlando or Longwood area with a Vag that can assist?
    Veteran Member Four Rings stereojorge's Avatar
    Oct 15 2013
    2014 Audi S4 P+ DSG, 2015 Audi SQ5 Prestige
    Tampa, Florida
    I'm very knowledgeable, but live in Tampa, you're welcome to come here!
    '14 Misano Red S4/APR Stage II+ DP ECU+TCU & UC/187mm Crank & AWE 57.55mm SC Pulleys/CMD Charge Chamber Intake/KW V1 Coilovers/EuroCode Sway Bars & AluKreuz/CR-15/034 Trans Mount/Apikol Rear Diff Mount/ECS Rear Diff Carrier Mounts/CMD Test Pipes/AWE Reso.Downpipes/AWE Track Exhaust 102mm Tips/Vossen HF-3 19" x 9.5"/Michelin PS4S'/StopTech Drilled Rotors/Akebono Euro Ceramic Pads/StopTech SS Lines
    Also: 2015 SQ5 Prestige | 2003 A4 Avant Quattro 6MT
    Previous: 2010 S4 P+ | 2008 A4 S-Line
    Jan 22 2016
    Audi TT and Touareg
    Orlando, FL
    This would give me an excuse to drive... ;)
    Quote Originally Posted by stereojorge View Post
    So you're familiar with the s4? There are quite a few in here I want! The emergency breaking, the video on the MMI (not sure if that's possible but many have told me it was) - and no I haven't researched it yet lol... The LED Wink disable.. Led Brightness.. Mirror Tilt.. brighter leds
    •Disable After-wipe of windscreen wipers
    •Disable amber corner lights
    •Disable amber side markers
    •Disable Key warning (keyless models)
    •Disable LED 'wink' on turn signal
    •Disable "Lights are on" warning
    •Disable NAV & Phone warning messages while entering data at speed
    •Disable Seatbelt Chime
    •Enable Adaptive brake lights
    •Enable Ambient Interior Lighting Control
    •Enable Automatic Gear selection shown in DIS
    •Enable Automatic Hill Hold Assist 'lite'
    •Enable Auxiliary ventilation
    •Enable Battery meter
    •Enable DIS with Efficiency Program
    •Enable Double Disarm Beep
    •Enable DRL Selectable via MMI
    •Enable DRL
    •Enable Euro parking lights that turn on signal at night
    •Enable fog lamp to come on for the same side as that turn signal
    •Enable Front Turn Signals as Parking lights
    •Enable Gauge Test/Needle Sweep
    •Enable Hidden menu in MMI
    •Enable Import CDs to MMI's HD
    •Enable Independent Fogs control with high beams
    •Enable Lap Timer
    •Enable LEDs remain bright for parking lights
    •Enable Rear Tail Lights on with DRLs
    •Enable Release Parking Brake without putting foot on Brake
    •Enable Release Parking Brake without putting seatbelt
    •Enable Remote Operation windows&sunroof
    •Enable Reverse mirror tilt
    •Enable Speed through MMI
    •Enable TPMS
    •Enable VIM on MMI
    •Set Audi parking system - Switch OFF Speed
    •Set Custom ADS settings
    •Set Headlight washer - cycles
    •Set Headlight washer - duration
    •Adjust Consumption in DIS
    •Adjust LED Brightness
    Oct 15 2013
    Tampa, Florida
    I own an S4 :-D Are you showing me the list you want or just the whole list? Because I know it like the back of my hand. Hehe :)
    Jan 22 2016
    Audi TT and Touareg
    Orlando, FL
    Oh, just showing the list. :) I don't want all of them. Hell, I don't even know what some of it is... But there are quite a few things on there I would like. What kind of beer do you like? lol
    Oct 15 2013
    Tampa, Florida
    Depends in the mood I'm in :-D First we need to plan accordingly!
    Jan 22 2016
    Audi TT and Touareg
    Orlando, FL
    Sounds like a plan... :) What days are good for you? Also did you do all the led's your self? I am terrified of tearing up the interior or scratching panels... =/ I was thinking of buying the kit from vleds or ecs
    Jan 15 2016
    Orlando, FL
    I'm looking for some VAG-COM help in the Orlando area as well. I'm retrofitting an AMI into my TT and need to code the RNS-E and the CAN Gateway. I live near downtown and work up in Maitland but could meet up anywhere close by. Thanks.
