Originally Posted by
14S4GWM
Just get Carista if you just want some tweaks.
Nevermind, I found it.. but I don't think it's going to support all of the things you can do with the vag... especially being able to have a video viewing option on the mmi screen. Or at least I was told this was possible.
Or these...
•Disable After-wipe of windscreen wipers
•Disable amber corner lights
•Disable amber side markers
•Disable Key warning (keyless models)
•Disable LED 'wink' on turn signal
•Disable "Lights are on" warning
•Disable NAV & Phone warning messages while entering data at speed
•Disable Seatbelt Chime
•Enable Adaptive brake lights
•Enable Ambient Interior Lighting Control
•Enable Automatic Gear selection shown in DIS
•Enable Automatic Hill Hold Assist 'lite'
•Enable Auxiliary ventilation
•Enable Battery meter
•Enable DIS with Efficiency Program
•Enable Double Disarm Beep
•Enable DRL Selectable via MMI
•Enable DRL
•Enable Euro parking lights that turn on signal at night
•Enable fog lamp to come on for the same side as that turn signal
•Enable Front Turn Signals as Parking lights
•Enable Gauge Test/Needle Sweep
•Enable Hidden menu in MMI
•Enable Import CDs to MMI's HD
•Enable Independent Fogs control with high beams
•Enable Lap Timer
•Enable LEDs remain bright for parking lights
•Enable Rear Tail Lights on with DRLs
•Enable Release Parking Brake without putting foot on Brake
•Enable Release Parking Brake without putting seatbelt
•Enable Remote Operation windows&sunroof
•Enable Reverse mirror tilt
•Enable Speed through MMI
•Enable TPMS
•Enable VIM on MMI
•Set Audi parking system - Switch OFF Speed
•Set Custom ADS settings
•Set Headlight washer - cycles
•Set Headlight washer - duration
•Adjust Consumption in DIS
•Adjust LED Brightness
- - - Updated - - -
homelessNY_LI
Try the regional section as well
Will do.. :) Thanks
