IMHO, there are 3 basic types of break in techniques plus an innumerable amount of variations. These are MY classifications:
1) Easy. This is what Audi recommends. For the first 1k miles, you don't drive over 5k rpms and basically baby the car with only gentle to moderate acceleration.
2) Aggressive. Often mistakenly called HARD. From day#1, after allowing the car to warm up to normal operating temps, do WOT runs, starting in first gear or D, to the redline. or just short of redline for the squeamish. Followed intermediately by taking foot off of gas pedal and letting car coast back down to normal speed in gear (engine braking). This is done no more than 2-3 times a day. WOT in any gear below redline as desired. This is done for the first 1K miles . After that, drive it any way you like.
3) Hard. Also called "Drive it like you Stole it!". From Day #1, no attempt is made to drive the car easy. WOTs to redline at will and often. Concerted effort made to drive car as aggressively as possible .
Most of you know by now that I am a proponent of #2 which is based on the MOTOMAN technique. However, in a true Motoman technique, you would drain out the factory synthetic oil, put in non synthetic break in oil for the first 1k miles, and then put synthetic oil back in at 1k miles. I do not advocate this, but in theory, it would be better for piston ring seating. You will find owners who have done each of these techniques who claim that they have no oil consumption issues. Let it also be known that there have been many reports of excessive oil consumption with the B8 S4 that were rectified with the replacement or repair of the PCV valve. However, in almost every case of excessive oil consumption with these cars(and others) have been with those who have used the easy technique. (other engine defects excepted). Actually, the Hard break in is better than the aggressive technique to get the piston rings to seat COMPLETELY. However, IMHO, the hard technique puts unnecessary extra stress on other moving parts in the engine, and drive train.
Also, there needs to be a distinction made between engine BREAK IN and engine WEAR IN. Engine Break in is about getting the pistons seated completely. You have about 1k miles to get than done. If it doesn't get done by then it will never happen. Engine Wear In, has to do with allowing the moving parts in the engine and drive train to mesh with each other. This can take up to 5k miles or longer to happen. While theses parts are wearing in against each other, Friction is a good thing. After, they have worn in, friction is your enemy. Wear in is why the engine feels stronger after putting 5k or more miles on the car. Engine wear in is why I don't believe it is necessary or even a good thing to change the factory oil at 1k miles. For 5k miles, some friction is good, after that, friction is your engines enemy.
