Results 1 to 8 of 8
    Jan 22 2016
    NZ
    Unhappy Help please! Lost FOB key - have emergency/plastic FOB in ignition - can't start?
    Hi guys...
    I have two standard keys - one stashed 300 miles away, the other probably down the side of a couch at a mate's about 20 minutes away (took my FOB with him I'm guessing, along with my chinos I lent him...) - and one emergency key with me, paired with the plastic FOB from the glovebox.
    I've managed to get into my car without triggering any alarm, and have the FOB in the ignition. Dash lights turn on, but I just can't get the car to start. Just a lot of clicking noises from the ignition when I push in... MMI not starting up. I have the push to start button too, which doesn't do a lot when pressed either...
    Am I missing something here?
    I have a 2010 A4 B8, 2.0T Quattro DSG S-Line, MMI 3G...
    Had a look around, couldn't find anything concrete, other than I may need to "re-code" my emergency key? Not much use if this is the case...
    Any help would be much appreciated.
    Veteran Member Four Rings 4ringnut's Avatar
    Apr 04 2015
    2019 Audi S4, 2017 Acura MDX
    Woburn, Ma
    Did you try pushing the fob to start the ignition instead of the start button?
    Pedal Responce first responder.
    Apr 04 2015
    Woburn, Ma
    Just to be clear. Your emergency key is inserted into the emergency fob? The fob is in the fobgina. And you tried pushing the fob to start instead of the button? Is that right?
    Jan 22 2016
    NZ
    Quote Originally Posted by 4ringnut View Post
    Yep, tried that first. That's when I get the clicking sound. It lasts for about 5 seconds after I push the fob in. Almost like something's not latching on... but have no problem when using the standard fob key in there.
    Also made sure both Audi rings are facing up, after coming across that tip on the forum.
    Cheers
    Jan 22 2016
    NZ
    Exactly right. Sorry, could've been a little clearer. Fobgina - one to add to the Audi vocab
    Apr 04 2015
    Woburn, Ma
    Is the clicking coming from the engine bay?
    Jan 22 2016
    NZ
    Nope, from within the mystical fobgina itself... Definitely that, or some other component behind/next to it. It sounds like it's trying to grab the fob or position it properly, only to repeatedly fail and make clicking sounds as it tries.
    Apr 04 2015
    Woburn, Ma
    Call the Audi road side assistance. I'm assuming they have the service in NZ. They may be able to walk you through it.
