I'm starting to uncover some of the issues, and beginning to fix them. But there are a few I would love to get some input/ideas from forum members.
- When accelerating in 1st gear, the center driveshaft makes a clunky/vibrating noise. I had this in a previous Audi, and it was the transmission mounts. Is there any consensus about which transmission mounts are used with the 6MT swap? The parts list says to use the mounts from the transmission donor, but other threads say to use the original mounts from the S6 tiptronic.
- Are there other things I should be looking at for this clunking/vibration? Is the center support bearing a common failure? Or the CV joints on either end of the driveshaft?
- I'm also suspicious of the mounts because when getting on/off the throttle (gently), there can be a bit of an oscillation. This would lead me to believe the motor/trans is moving around more than it should. I got about 3/8" of movement on each mount when I used a jack to lift each side of the transmission.
- I didn't detect any motion on the engine mounts. Don't these mounts have sensors in them that would indicate when they have gone bad?
I'm sure there will be more things as well, but the vibration is my initial concern. It seems to be losing a little bit of coolant over time, but I haven't noticed any leaks on the right side (oil cooler pipe). I need to check the reservoir for cracks. I also have a small hydraulic fluid leak, but it appears to be coming from the reservoir or hose from the reservoir. I'll be cleaning/inspecting that soon too.
Thanks for any tips/information you can share about the vibration.
-Dan
