I purchased an Audi A4 2009 2.0 everything its amazing about this car except that I'm having battery or electrical problems, purchased the car with no warranty I replaced the battery with direct fit 94R-DLG, the car keeps dying after a couple weeks and gets worst with the cold tempetures so i decide to purchased the ROSS-Tech Cable and scan my car with the engine running so here are the results and again please help me
Address 01: Engine (DL0MA-CAEB) Labels: 06H-907-115-CAB.clb
Part No SW: 8K2 907 115 AL HW: 8K2 907 115 D
Component: 2.0l R4/4V TF H14 0001
Revision: E1H14---
Coding: 0104010A190F0160
Shop #: WSC 06120 444 122157
ASAM Dataset: EV_ECM20TFS0118K2907115AL 001001
ROD: EV_ECM20TFS0118K2907115AL.rod
VCID: 79F9B0D8F87B1BF61A-802C
1 Fault Found:
7144 - Please Check DTC Memory in CAN Gateway (J533)
U1008 00 [047] - -
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 21
Mileage: 173199 km
Date: 2015.12.22
Time: 09:31:00
Address 19: CAN Gateway (J533) Labels: 8T0-907-468.clb
Part No SW: 8T0 907 468 M HW: 8T0 907 468 H
Component: GW-BEM 5CAN H06 0095
Revision: GB300043 Serial number: 4300G091140028
Coding: 000303
Shop #: WSC 02391 823 56573
VCID: 4B953A10EA675966F8-801E
3 Faults Found:
02071 - Local Databus
012 - Electrical Fault in Circuit
Freeze Frame:
Fault Status: 01101100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 231
Mileage: 173206 km
Time Indication: 0
Date: 2015.12.22
Time: 09:38:46
02252 - Generator
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 19
Reset counter: 243
Mileage: 173207 km
Time Indication: 0
Date: 2015.12.22
Time: 09:39:53
00458 - Control Module for Battery Monitoring (J367)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 19
Reset counter: 243
Mileage: 173207 km
Time Indication: 0
Date: 2015.12.22
Time: 09:39:53
Address 46: Central Conv. (J393) Labels: 8K0-907-064-46.clb
Part No SW: 8K0 907 064 F HW: 8K0 907 064 F
Component: BCM2 1.1 H80 0145
Revision: 00002001 Serial number: 0116792945
Coding: 0106063A007A440400B001
VCID: 336542F0929721A690-8066
Subsystem 1 - Part No SW: 8K0 959 719 HW: 8K0 959 719
Component: GTO BF H06 0040
Subsystem 2 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H03 1301
Subsystem 3 - Part No SW: 8K0 959 591 HW: 8K0 959 591
Component: J245 PS034 H06 0037
2 Faults Found:
02615 - Fuel Tank Cap; Lock
009 - Open or Short to Ground
Freeze Frame:
Fault Status: 01101001
Fault Priority: 2
Fault Frequency: 1
Reset counter: 231
Mileage: 173210 km
Time Indication: 0
Date: 2015.12.22
Time: 09:45:24
02616 - Fuel Tank Cap; Unlock
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 231
Mileage: 173210 km
Time Indication: 0
Date: 2015.12.22
Time: 19:32:47
